Here is another post for a "How to thread".
The manual is very poor on this topic. After aligning the wing to the fuselage one is to use tight fitting drills to transfer the wing hold down holes to the fuselage.
But we are not to tap threads in the hold down plates. Rather we are to use threaded inserts. These inserts have a much larger diameter than the holes just drilled. It is impossible to drill a hole larger and still keep it on position using a drill bit. To enlarge the holes one needs to use a reamer if one wants to save all that hard work, keeping the wing aligned, when it is bolted down.
My kit has a major problem in that the port (left) wing has the through hole about 4mm too far outboard. The result is that this hole is only half on the hold down plate in the fuselage. This also meant that there was no edge margin for the insert's flange. To keep from violating the outside surface of the fuselage I had to file a flat spot on the insert flange. With the drastic difference in material properties between GRP (Glass Reinforced Plastic) and plywood, I had to hand grind this hole to allow the insert to fit. I allowed this insert to float in the hole about 0.25mm and relied on the hole in the wing to align the insert as the epoxy cured.
This out off position wing hold down seems to be an issue with the factory fixturing as there are more than a few reports of this issue.
