Well, it looks like the only real tedious job is cutting the trough for the wing rods. I used a ball mill in my Dremel tool to take out the bulk of the material. I then used the end of the receptacle tube to bring everything to final size. and last I ran the tube to burnish the trough to make sure it was a uniform feature (No high spots that might interfere with the lamination of the two wing sheets). Well, I wish the instructions would have mentioned that the trough is not centered between the laminations, as one needs to take into account the dihedral. So it looks like I’ll need to make some clearance (slop) to allow for some dihedral. I’ll need to fill this up with epoxy and micro-balloons.
That's another deviation in the kit. The parts list, calls out this tube as aluminum. My kit was supplied with a brass tube. I wonder if this was done out of concern for the corrosion issues associated with aluminum in contact with carbon? (You might recall from your high school chemistry that aluminum and carbon are at the extreme ends of the galvanic corrosion scale.) Or was this a strength/ weight issue to aid on the slope?
