Two ESC FrSky Neuron 60s: Telemetry of one ESC always shows only zero values 0.0
PeterM
Hello,
I have two ESC Neuron 60s. I would like to see the telemetry values such as rpm or temperature from both. Unfortunately this only works with one ESC, the second one always shows zero values.
My setting:
  • Transmitter: Radiomaster TX16S with EdgeTX 2.10.5
  • Receiver: FrSky X8R
  • ESCs: 2x FrSky Neuron 60S
What I have done so far:
  • Connected individually, the telemetry of the ESCs worked. All values were displayed. But only when they were connected individually.
  • I changed the physical ID of the second ESC from 16 (default) to 17 via FrSky SBEC LUA Script (of course connected individually). I also changed the ApplicationID from 0 (default) to 1.
  • I have not changed the values of the first ESC. The settings in BLheli are also set to Physical ID “off” (default) and Auto Telemetry to “on”
    => different physical and app IDs => there should be no conflict
  • Now I have connected the two ESCs to the smart port of the receiver via Y-cable
  • All sensors are recognized and are also active (indicated by flashing dots)
  • The values of the second ESC with the changed ID 17 are displayed correctly (e.g. the voltage in V)
  • The values of the first ESC are always set to “0” (but the sensor is indicated as active by flashing dots)
  • The telemetry values of the SBECs installed in the ESCs are displayed correctly (separately and completely). The problem therefore only affects the ESC telemetry values.
  • I have now set the first (previously unchanged ESC) to physical ID “18” and app ID “2”.
  • Then connected both again => same picture: all sensors recognized, but this time the values of the second ESC with ID 17 are displayed with “0” (had worked before) and the first ESC with ID “18” showed all values. SBEC values all OK again
I do not understand this. What am I doing wrong? There should be no problems with different IDs.
I am very grateful for any advice. Thank you very much!
This sounds like a Edge TX issue. I would contact them and see if this is anissue.
