ESC Neuron 60s: Changing SBEC voltage does not work via LUA script
PeterM
Hello,
I have a “FrSky Neuron 60s” ESC and a “Radiomaster TX16S” radio with EdgeTX 2.10.5. The receiver is an X8R with the latest UNI firmware (v83).
Now I would like to change the SBEC voltage of the Neuron 60s via LUA script. I downloaded the LUA script from the FrSky website. When I run it, however, no values are displayed, only “---”.
What am I doing wrong? I found a video on YouTube that describes the procedure in exactly the same way.
I am very grateful for any advice!
Update:
As a workaround I flashed my TX16S back to OpenTX 2.3.15. Its SD card package contains a FrSky SBEC script that does work (on OpenTX 2.3.15). By using this I was able to set the voltage and physical ID to the desired value.
Afterwards I flashed my radio again to the latest EdgeTX version. Voltage is still set correctly :)
