We have UNI-RX available now fore the following receivers:
We have the remote instal version available and I'll upload that here along with the authorization script you will need to active the firmware for each of your receivers. I'll attach version 54 to this thread.
In this zip file you will find the following files:
Activate,lua is a script that you will install into your transmitter (will go in the script folder on the SD card). The FRK files are the different versions of the UNI-RX firmware for the named receivers.
- Find the correct firmware for your receiver and burn it onto your receiver in the same methods used for FrSky firmware. (any method can be used.)
- Then bind the receiver to your transmitter like normal. But the receiver will not output anything until activated.
- Now run the activate,lua script on your transmitter while that receiver is bound to the radio. This script will give you a code, this code is then emailed to one of the FrSky dealers working with UNI and they will convert your code to an activation key that will be entered into the script on your radio.
- You now have Uni up and running.
Once the activation is completed you should never need to repeat it. Updates will work automatically.
Hopefully we can get a video up that shows the dirty little steps in finer detail. Writing it all would wear out my little fingers.
