hotdogx
User
- Joined
- Jan 3, 2019
- Messages
- 39
- Reaction score
- 10
I have a new X-Lite TX and Archer GR6 RX. Have it all set up in a DLG that uses two Dymond D47 servos in the fuse and two Hitec HS-45 servos in the wings. During setup the GR6 RX was outside the fuselage, running off a 4.8V 250 mah NiMH battery, and no servo jitter. I installed a 4.8V 350 mah NiMH and the GR6 RX into the fuselage (battery in nose, RX behind battery, and two Dymond D47s behind RX) and I now have significant servo jitter on the two Dymond D47s. I can eleminate it by grabbing one of the antennas, so that tells me the telemetry transmission is getting into the two Dymond D47 servos. Moving the antennas as far forward as possible does not cure the issue. My conclusion is I need to replace the Dymond D47 servos with a different brand, perhaps some with metal cases like the KST servos.
Does anyone have recommendations on servos that are not affected by the GR6 telemetry RF?
