I'm stumped. I just tried everything I could think of with two of my RX8R and two of my X8R receivers but I still couldn't get any of them to bind with telemetry disabled, although they all work properly otherwise. I also tried bridging signal pins 3 & 4 during bind and that also failed. In every case I hear "Telemetry lost" when I turn the receiver off and "Telemetry recovered" when I turn it back on. I'm using OpenTX 2.3.15 with a Taranis X9D+. What could I be doing wrong?
I just tested an X8R (UNI v57 firmware) and was able to turn telemetry OFF and ON during bind using X9D+ using OTX 2.3.15 with internal XJT firmware FCC v2 "2.1.0"
Then I downgraded my internal XJT to FCC v1 "170317" and still was able to turn telemetry OFF or ON at bind.
It then occurred to me that back when the telemetry OFF or ON was introduced, the X9D+ internal XJT also had to be upgraded to be able to use this bind option.
I believe you are running an older version 1 firmware on your internal X9D+ XJT causing telemetry not allowed to be toggled OFF ?
If you wish to remain on version 1 firmware you would need to upgrade it to the latest v1 available to be able to use the telemetry OFF or ON options.
It's hidden the same as above, on the X9D Plus Download page, but here is the direct link to the latest XJT v1 firmware needed.
https://www.frsky-rc.com/wp-content/uploads/Downloads/Firmware/XJT/XJT-Ver170317.zip
It has both "EU" (Europe or LBT) and "NONEU" (NonEurope or FCC) versions.
You would need to copy "XJT_NONEU_170317.frk" to the FIRMWARE directory on your SD card.
Navigate to it, select it, and then select "Flash internal module" and wait for the progress bar to complete.
Hope this helps - Rich
EDIT: I found the RCGroup posts back in 2017 referring to the internal XJT update was needed to have bind options available on the X9D+
It starts here
https://www.rcgroups.com/forums/showthread.php?2823315-OpenTx-2-x-x&p=37370566#post37370566
