QX 7 Switch change
oldhamram
Joined
Nov 2, 2018
Messages
2
Reaction score
0
Hi all
I want to swap round the sf and sh switch so I can get throttle hold on the right hand side of the radio.
Has anyone done this, I am new to this radio.
cheers
Gliderguy
Joined
Apr 9, 2018
Messages
23
Reaction score
1
I have done it. It's quite easy actually. You can't move each switch from one side to the other because the wires won't reach but you can either remove the wires at the switch then re-solder them or release the wire and connector from the connector block (which is what I did) and swap them from side to side. Then you just have to reassign the switches in Otx and you're done.
oldhamram
Joined
Nov 2, 2018
Messages
2
Reaction score
0
Thanks for the info,i will do as you suggest
Cheers.
