Looking for a spinner supplier
Txmustangflyer
Strong User
A tru turn won't work. The way they mount is not adaptable to the zenoah.
I need a 5.5 inch parabolic P 51 spinner it can be any notch as I'll have to mofify it for the varioprop, but I need a 4 blade basic notch.
Aluminum, CF, plastic, at this point I don't care, with back plate.
Mounting has to be by either perimeter screws from cone base to back plate OR a prop nut adapter (thay can be screwed onto a stud) and mounting screw.
I am open to international manufacturers at this point. Dave Brown has none in stock.
If you know of any source worth exploring, please drop a link, or email.
Rafael, If you can find an sts for one and have a suitable material and can 3d print one, Let me know.
Specs: 5.5 inch parabolic (P51) 1/8th inch thick back plate back plate. 4 blade, center line of blades is at 15.5 mm from back plate surface. Blade thickness at cone intersect 1.5 inches. Back plate center hole 10mm.
Did you call TruTurn and did they tell you they wont make you one that will meet all your requirements. They have been good people to work with in the past.
Yup, had a long email and phone exchange with them. They no longer do perimeter mount spinners.
I found one. Fighteraces.co.uk. Phil makes perimeter mount spinners. Aluminum back plate, carbon fiber cone.
Rafael is also 3d printing one for me to test.
