j ferguson
User
Mostly done. It now weighs 2.2 lbs and CG is still an inch behhind the fore-wing trailing edge.
I still have to print another hatch cover (for snugger fit), calibrate the S6R, and make sure the prop doesn't drag. It is a 10X6 but I should probably be safe and go to a 9X7. I made a little stopper so the blades won't eat the rudders nor spin up inside out. I'vd located a not-so-nearby r/c flying field which doesn't have a pond at the end of the runway.
The elevon hinges are those nice small Du-Bro nylon ones with the brass pins. It was a bit of a challenge to keep them aligned while I glued them, but elevon motion is pretty smooth so I must not have screwd it up.
I have a question. The elevons on the real(!!) SB300 are conected to the wings by continuous tape or something similar, hence no gap in their wings. Would you close this gap?
I've thought of gluing thin vinyl strips one for each wing underneath the aft edge to close this gap. What do you think?
Hopefully there will be a calm day next week and I can go out to see if it will fly.
John
John
