Powering RX with a y harness
Rascal
Joined
Apr 24, 2024
Messages
5
Reaction score
0
Location
Sequim WA
I've run out of channels so is it possible to power the rx thru a Y harness on one of the channels (I don't wish to use the esc)
Fair winds
Rascal
Joined
Nov 29, 2017
Messages
7,856
Solutions
2
Reaction score
4,580
Location
Novato, CA USA
Sure.
I'll add just to be a bit careful if you have a lot of hungry servos plugged in, the servo connectors should not be trusted to handle a bunch of amps.
iti20090
User
Joined
Feb 3, 2020
Messages
16
Reaction score
19
Fair winds
Rascal
For simple slopies, I am a fan of the Corona FHSS four channel receiver and been running dual aileron/elevator/rudder through a Y lead with no probs.
I personally would not extend that to flaps though, as Wayne intimates, starting to get too power hungry :)
Cheers
Dave
gnichola
Joined
Jan 23, 2018
Messages
581
Reaction score
203
@Rascal if I am reading your message correctly, you are thinking that you should Y the battery into the lowest current servo. If I am misreading your message, you can stop reading now. The current going through the Y connector is the same regardless which servo you use it on. The total current for all servos is running through that one lead.
If you are concerned about that, another thing you could do is Y the battery lead as well as Y'ing a pair of servos, spreading the load across a pair of connectors.
Or, you could buy something from this page: https://alofthobbies.com/collections/power-distribution
Rascal
Joined
Apr 24, 2024
Messages
5
Reaction score
0
Location
Sequim WA
Thanks guys, simple solution was to buy a TD R10, it wasn't my first choice but it is better than the Y harness and possible issues.
Fair winds
Rascal
