XM+ as a redundancy receiver
Fireflite88
Hello Everyone, I purchased a couple of the Xm+ receivers for two larger gassers I fly. After losing a model a few months ago and wading through those issues I wanted to add a layer of protection. Someone in a previous thread had mentioned using the XM+ as a redundancy receiver. I want to add these to the tail of each plane.
I searched the forums and didn't find any info on how to add these to the X8R Pros that I am running with. I did find a video by RCDIY and I think I understand but I wanted to verify with the community here on the Aloft Forums. I hope that someone can share their experience.
If I understood correctly I would bind the XM+ in D16 mode 1-8 w/No Telemetry using the same RX number as the X8R Pro. Then connect the XM+ into the SBUS IN port of the X8R Pro?
If anyone can verify or give me any feedback it would be very much appreciated.
(24 hours later and nobody got to this)
You got it.
Just to be clear you don't need to separate the MX+ from the main RX to bind.
The MX+ only offers RF redundancy only (S-Bus output). Should the main RX have any other type of failure the MX+ will not offer redundancy (S-bus decoder, electrical bus failure etc.).
I too find the search function a bit lacking. It might help if the original poster would add tags.
Place the antennas for each RX 90° to each other. This is to address the fade issue with high frequency RF.
Thanks for the reply @Konrad. So add the xm+ would not help with reception? Or added reception for a lack of better words?
I was under the impression that adding it to the X8R Pro was similar to adding a satellite receiver in the Spektrum world?
Yes it is very much like adding a Spektrum satellite.
Not sure what you mean by reception. No, it will not add range. It may add a secondary signal path to get around RF blocking material that might get between the TX and the other RX's antennas.
Okay that's what I thought but that's not how I conveyed it. So that is exactly what I want to do. I'm just not confident with the binding procedure to add it to the existing Rx. Also will the XM plug into the SBUS in or out on the X8R?
S-Bus in. I think this IS one of the few things the manual actually states.
To be honest proper orientation with the antennas will have a greater effect on signal quality than the second RX in most applications.
What Im getting at is don't be sloppy with the X8R pro's antennas.
Give me an idea of a good orientation for the antennas inside my fuselage.
@Konrad okay perfect . I generally dump one out the side of the fuselage and one straight back or down. Do you think using clear push rod tube to help keep them in place would be a good Idea? Just thinking that the antennas that dump out the side would get blown backwards in flight.
No need to go outside unless the lay up is carbon. As I think your fuselages are balsa I'd keep the antenna inside (This is one of the scale benefits of 2.4 gHz.
Place one antenna on ether side of the largest RF blocker (Lipo battery pack or aluminum engine block). Place these 90° to each other.
I like antenna tubes. To test their material I place it in a micro wave oven and heat for 8 seconds If they warm up they are not suitable for antenna tubes. Nylon is not good as it absorbs water (heats up in the microwave oven).
Place the redundant RX antenna 45° to the main but also 90° to each other.
Basically looking with your X ray eyes turn the model in all directions You want to be able to see at least one antenna around the RF blockers in your model. As you have CDI get that as far away from the RX and antennas. That is one of the few real benefits of a redundant RX, getting one RF section away from the CDI.
