J_B_Wingnut
I went to check the telemetry log after a recent flight, and discovered that my transmitter has not been recording logs for the past couple of weeks (probably a couple dozen flights on three or four airplanes). Logging had been working perfectly for a couple of years until suddenly it didn't. I've spent a lot of time over the past few days trying to get it to start recording logs again, with no luck. I've provided the details of the situation below. I've tried everything I can think of to get logging working again, and have run out of ideas. It's probably something simple stupid that I've just overlooked. Any suggestions on what to try next would be appreciated...
Indications:
1. The only thing that changed since the logging ceased is that I did some minor programming changes on ONE of my models. I added a "suedo-lap counter" display for pylon racing, that uses global variables to count and display full-elevator pulls. I have not touched programming on any of my other models in months.
2. I currently have no logging on ANY of my models. I use 8XR, 6SR, 4XR, S6R, and S8R receivers on the various airplanes.
3. Logging is enabled via Special Functions and Logical Switches: Logging is supposed to begin when the motor is armed using Switch F aft.
4. The transmitter receives and displays real-time telemetry data.
5. The "SD card writing" indicator/icon is displayed on the transmitter screen when the logging should be occurring.
6. All other functions appear to work correctly on all my models/airplanes, including throttle arming, flight controls, rates, expo, etc.
7. I have never opened the case of the transmitter in the two years I have had it, and it has never been dropped or abused. I replaced the battery three or four months ago. I keep the transmitter in a Taranis soft case.
Things I've Tried That Didn't Resolve The Problem:
1. I made sure all my Sensors listed on the Companion Telemetry page were checked (for all my models)
2. I re-checked the throttle arming and logging logic in Logical Switches and Special Functions, and confirmed operation in the Companion simulator using the Logical Switches, Special Functions, and Global Variables windows.
3. I went through each of my airplanes, running them, to make sure they all functioned properly, and to confirm they all have the logging problem.
4. I changed my logging logic to a simple on/off switch independent of throttle arming.
5. I checked the SD card slot for dust and foreign objects, and proper operation of the spring-loaded card insert/removal mechanism.
6. I checked the capacity of my SD card (1GB card that has only used 300Mb)
7. I inserted the SD card into my computer to ensure all the files are really there, and can be accessed.
8. I transferred all the SD files onto a new SD card, and put the new card into the transmitter.
9. I reverted to a two-month-old EEPROM file backup of all my models (I know for sure everything was working back then)
10. I updated the firmware to version 2.2.2 (I had been running 2.2.1)
Indications:
