Fairly new to the X20RS and looking for help to setup a 4D throttle with two curves controlled by a switch.
I will run the ESC in 4D mode continuously and want to use the switch to change the throttle curve from 3D mode 0% to 100% to 4D mode with the curve at -100% (full reverse thrust) to 0 at center (throttle off) to +100% (full forward thrust).
I will also need a separate throttle cut switch for safety. I see where that is available in the standard mix.
Thanks,
Jeff
Thanks,
Jeff
