Call Me Al
X20 ethos will not arm a known good esc & motor combination. The combination worked perfectly with a Hitech transmitter & receiver. Switching over to the X20 & X8R ACCST receiver the ESC single beeps every 4 seconds. The throttle hold is set to -100 and I can see it working. I have reset and recalibrated the ESCwitout making any change. If I power the receiver from a battery pack and put a servo on the motor channel it works perfectly. I have experimented with other ESCs and found that Castle Creations, Jeti, & Scorpion ESCs seem to work properly with the X20. I think the R8-PRO PRO acted the same way. Unfortunately my X20 seems to have locked up with the power button being blue and without the ability to turn the unit off or on. I have it on charge now, but not sure this will help. I'm hoping it's just a setting I have overlooked.
