X18 has lost some software while I was removing duplicate software. Now my menus below the windowed timers is blank. Help
my radio wont allow programming. Can SD with startup software be purchased?
The radio Flash memory contains the startup files. The SD card has bitmaps relating to the menus, the SD card also has your models and audio clips on it. You most likely deleted these. Do you have Ethos Suite on your laptop. Had you performed a backup using Ethos Suite to your laptop. If you have you can restore lost files this way.
Hi! I replied to your last email this morning but I Just saw this, it looks pretty bad so let's just get it back over here, I'll give you the address in the email.
Thanks Jarron. The support I received from this forum was appreciated. I discovered my mistake. I repaired the loss of the lower menu and some widgets by going back to the original firmware. A new friend suggested that the 3 firmware updates I upgraded to were too much. Live and learn!
