X12S charging issue
dariushz1
New member
I noticed that when fully charged the battery voltage of my new X12S never goes higher than 10.9 volts!! So I took the battery out and cycled it on my fancy charger and it peaked at 12.0 Volts so there is nothing wrong with the battery, but the charging circuitry of the transmitter doesn’t let the battery to fully charge, does anyone else has this issue? Is there a fix for it?
Try using it now and see if your Horus can maintain the charge better now. Seems external charging usually cures this once and forever.
dariushz1
New member
well I fix the problem by replacing the stock charger with another charger that has a slightly higher output (13.5v) now the batteries do charge up to 11.7v which is more reasonable
