Hi guys.
After reading a lot about installing ACCESS module, I'm still confused.
What is a correct way of installing software after installing module in to Horus X10s?
Currently, I'm on OTX 2.3.15, and I don't have a plan to move to ETHOS at the moment.
Is this correct way:
1. Install FIRMWARE-ISRM RF Module ISRM v2.1.10 for ACCESS Upgrade Module Kit (X10 & X10S & X12S)
2. Install OTX 2.3.15 with internalaccess option via Companion
If this correct way, after update should I bind again all receivers? I also have UNI Firmware installed on few X8R,RX8R PRO and Sx8R
Third question:
All my non UNI receivers are flashed with FCC Firmware, but I get EU Internal ACCESS module.
If I switch from EU to FCC with LUA Script will my FCC receivers still work without flashing to EU firmware?
I saw this option at that link:
blog.seidel-philipp.de
Thanks in advance
Edin
Third question:
FrSky ISRM Modus (EU/LBT & FCC) wechseln per LUA Script
In diesem Artikel erfährst du, wie du innerhalb von Sekunden dein FrSky ISRM Modul von LBT/EU auf FCC umstellen kannst.
Thanks in advance
Edin
