X10 and X12 Horus upgrade to ACCESS
I would not worry about F-port. LOL But yes, I think we will eventually see F-port available for those receivers.
Hi Wayne,
I am from India and had bought a Horus X12S from you and had a friend bring it over. Would like to upgrade it to ACCESS capability. Unfortunately Frsky had promised an upgrade path more than a year ago but nothing happened. I plan to replace my ixjt RF board with the X10 isrm non-EU ACCESS board. Do you stock it and can you ship to India ?
Due to border standoff between China and India it is almost impossible to get anything from China. I would like to purchase two extra X12S antenna and an SPORT RPM/Temp sensor along with the isrm board. Grateful if you would let me know the prices.
Yes, we have the X10 upgrade boards in stock, just not on our site and yes we ship to India. Send us an email at contact@alofthobbies.com and let us know the items you would like and let them know I sent you. We may be able to ship these items in a protected envelope to keep the shipping a little more reasonable.
FrSky will be putting development money into the X series of RX when they have come out with the Archer series that covers much of the same market?
Actually there is a push for them to allow the Archer line to support ACCST. Then they can kill off the X series. The Archers are just modified X anyhow.
Why you ask? Because they are retiring many of the 8 channel X series. We asked about keeping them in production, they will do that for us service dealers, but at a price. So we countered with the simple solution, just offer ACCST on the Archers. Problem solved.
There is quite a push for that indeed but I would be VERY surprised if they did that since it would go directly against the "plan" they seem to have been working towards for the past year or 2.
Unless the situation got really dire of course.
Buenas tardes
I'm Andres Cuadros from Lima Peru
I have a X12S from 2016 to which I am changing the motherboard because the original has had a fault in the power button
I have also bought the ACCESS Upgrade module Kit with the PARA WT
At the same time I have a R9M 2019 that I want to install on the radio to use in ACCESS and not as ACCST as it works now.
The questions are
By installing the ACCESS UPgrade module, will I be able to have ACCESS and ACCST as it happens with my Taranis 2019 from the X12S?
Do I understand that I must also do the hardware modification to be able to use the R9M in ACCESS? or when installing the Upgrade module, I no longer need to make the modification.
If so (that I should make the modification) is there any special guide considering the Upgrade module?
Thanks
Your radio should be like the Taranis 2019 after the upgrade and firmwares are done.
Think you just need an R9M that is ACCESS compatible and you will be good to go. Maybe I didn't understand this question..?
Thank you Kilrah and Henny
So the X12S hardware mod is absolutely necessary
Understood
Waiting for the inverters to arrive to Lima.
Regards
Is this why the X8R’s and S8R’s are out of stock and will you be getting any more in?
I warned another X12S user last summer when this all started that he should probably buy a few spare Rx’s.
We are being forced to replace all equipment for no other reason than greed.
I guess I am at the point of deciding the direction I will be going. If I have to garbage 2 X12S’s all Rx’s and sensors I most likely won’t buy FrSky again. Sure as hell not a “new Tx that looks suspiciously like the last flagship they failed to support “ The only real saving grace of the X12S was its compatibility with Opentx.
There are still plenty of X, RX and GRX series ACCST receivers available. No need to junk anything.
I have been shopping for X8R and S8R Rx’s they show in stock until you try to order. I was trying to complete 3 more models for this season. Figured by then I would start the transition to an alternate brand.
Try the RX8R Pro its a bit more expensive but a later model receiver, if you only need 6 channels the RX6R is a great receiver.
I require a minimum of 7 channels, 9 with retracts. Just the way I like to program my models. I do have a couple of RX8R’s still in the package put away. I was looking for a couple of S8R’s for use in transitioning to EDF’s. That was one method other than using a separate gyro unit. I used a gyro when I learned to fly rotary wings. I turned down the gain, eliminated individual axis, eventually removing the unit entirely after achieving proficiency.
It would appear others have read the comments in this thread. S8R average price $65. Most claim they will ship from US if possible. Horus doesn’t even list them anymore. Hmmm. Sounds like no longer available to me unless you want to take a chance with dealing with non refundable Chinese sources or some jerk trying to make extra money off the situation. At least other manufacturers like Futaba while somewhat limited, Do support their products over the actual useable lifetime. I guess being in the business for decades makes a difference. In hindsight I should have been as loyal. My bad.
Well depends what you call a receiver life span. The X8R has been available for a very long time and is still available just appears to be in short supply.
You could use the RX6R and a Sbus to PWM decoder to give you 10 PWM outputs.
I was considering that route. However looking at the bigger picture I am seriously thinking of just cutting my loses. As far as Rx life span goes that depends on how much supportable product you as a manufacturer dump on the market. Do you institute a major change based on better technology or just to secure a market share. To make a change that only serves to shut out competition does not show loyalty to those people who only use FrSky products with their Tx. To kill the opportunity to use OpenTx in future products, which I consider to be the best innovation in our hobby we could have hoped for is total crap.
Do you really believe the chinglish manuals we get are the example of inept people or psychological warfare. Make the decision for yourself.
Not sure what you are referring to. 99% of the manuals to do with FRsky operation has to do with Opentx. The 1% manuals to do with binding or setting fail-safe are pretty straight forward in my mind. If Futaba is your thing then go for it, in the end that is your choice. I do not find Futaba manuals any easier to navigate.
It is hard to wrap my (old) head around the changes. I need some help sorting things out. I have a first run 2016 Horus on which I replaced the gimbles due to the wire issue. I have 40 plus models running on RX4or6R, X8R, SXR, X4R, D8R, and D4R and probably a few others. I am still on D16v1 because I can't figure out where I am heading and my OTX is 2017 vintage because I really hate the update process with the Horus. Last fall I recently got an X-Lite and have 15 model (some new and some migrated over from Horus) on that, mostly on RX4or6R D16V2. I love the X-Lite, but transferring models from Horus is tedious because of the switch assignments and some use too many switches anyway. I am not awed by the new ACCESS features, except it would be nice to share some models between transmitters and provide some backup.
I'd like to either have the X-12S converted to ACCESS or perhaps abandon it and get an X-10S Express, and use an external module for the D-8 and D-16 receivers that can't be upgraded. I looked at the X-20 and it seems nice but the lack of OTX is a deal breaker because there is no way I want to learn a new OS and try reprogram 40 models and I have no need for dual frequencies, Bluetooth, or other bells and whistles and I don't think I like touch screens. I do want a quality TX though.
I am thinking it may be best to just get the X10S because I can then migrate models over one at a time and upgrade the receivers. I hope I would like it as well as the Horus. A little lighter would be a plus too.
Or maybe I should just get a new Taranis ACCESS, back to where I started in 2013.
I have found with the X-Lite that I don't need a big, fancy color display. I looks nice on the Horus in the shade, but I can't see it and don't really need to when I am flying.
Or do nothing at all!
BTW, was there a run on Receivers at Aloft? Almost none available! Nothing for the two tiny < 250g gliders I am building.
