X10 and X12 Horus upgrade to ACCESS
This makes no sense as the upgrade module for the X10 works just the same as the one in the X10 Express.
You would think, but in testing it has been found that the boards give difference results. Some will be better than others. The testing was done by a service dealer that was trying to identify the range issues of these boards. He ended up putting several different upgrade boards into the same radio and documented the outputs.
Yeah, my point is not that they would all be great, but that both types should have the same variance.
That is unless FrSky tests the radios to make sure they are OK but don't care about the upgrade modules...
There is something fundamentally different between the upgrade ISRM module and the ISRM module in the X10S Express, Physically they look the same. I installed the Upgrade ISRM module in my X10S Express radio and flashed it with the Express firmware and it didn't work.
Different firmwares for the Express from the X10S Upgraded - Thus another issue, it becomes a one off wired radio. Think it better to sell off the old X10S and buy the new Express. Especially since Frsky dropped the prices on the Express.
The only difference is that the upgrade module has the "authentication check" that the normal one doesn't, and FrSky made it so you couldn't run the firmware of the normal one on the upgrade one for that reason. Both with regards to hardware and actually useful functionality they should be identical.
I mean there is no reason they wouldn't be.
If they aren't it's either bad QC, buggy or intentional, none of which are desirable explanations.
I am curious if there are still plans for a Horus X-12 ACCESS upgrade that Aloft would be able to do and if so, what the cost (not including shipping) would be? I don't think I would need a wireless trainer option.
In post #25 it looks like Wayne has stated that the upgrade isn't worth it.
Now cost and value being different concepts...
Hi Konrad. Yeah, for the X10 just get the X10 Express. But I already have the X12S and I like it. I am still flying on the V1 D16 with dozens of receivers. I figured if I was to go all to the trouble of upgrading I perhaps should go all the way to ACCESS if it were available and working , and let Aloft get the TX updated and working. If that isn't feasible, I'll probably just leave things as they are.
Got it, Sorry I missed that.
There is a huge difference between the ACCST v1 to v2 safety upgrade verses the wholesale revamp of the protocol from ACCST to ACCESS.
Remember with ACCESS you'll need to upgrade most of the RX hardware. With the ACCST v1 to v2 upgrade most receivers only need a firmware update.
I understand the TX hardware needs hardware upgrading if it is even possible. Please explain about "RX hardware" upgrade.
To fully use ACCESS you need to change to the Archer receivers.
It only looks like 5 of the legacy RX can be upgraded to some level of ACCESS.
Thanks. You know, I hate changing things, but thought if I did, I might as well get up to date. I certainly don't want to upgrade dozens of receivers. And honestly, I don't need any advanced features. I still have a Taranis from the first batch that was sold, with an old version of Open TX, with many planes with D series receivers, that work just fine.
I can cross ACCESS off the list. I like my Horus X12s a lot. I am tempted to try an X-Lite for some very small models, but I guess I'd stick with the D16 mode if I go there.
Yes, we can install the X10 RF upgrade into the X12S and this will allow ACCESS onto the X12S. We need to add another antenna to the radio. I'm not 100% current on this but pretty sure that this is an option that does work. I can double check to make sure. I know a number of folks have done it, but not sure of the software support for the hybrid radio.
Hi Wayne,
I am from India and had bought a Horus X12S from you and had a friend bring it over. Would like to upgrade it to ACCESS capability. Unfortunately Frsky had promised an upgrade path more than a year ago but nothing happened. I plan to replace my ixjt RF board with the X10 isrm non-EU ACCESS board. Do you stock it and can you ship to India ?
Due to border standoff between China and India it is almost impossible to get anything from China. I would like to purchase two extra X12S antenna and an SPORT RPM/Temp sensor along with the isrm board. Grateful if you would let me know the prices.
The later X series receivers fully support "ACCST" and "ACCESS" like the GRX8, GRX6, RX6R, RX4R, RXSR. The Archer receivers only support "ACCESS".
Really? Will the 5 (X series) RX you list support "F-Port" when converted to ACCESS? If not, then I stand by by statement that the X Series upgraded to ACCESS can not incorporate the full feature set of ACCESS. It is my understanding that ACCST was dropped as it is obsolete and to make room for the full features set offered with ACCESS.
