X-ray Racer - New Product & Build
Just thinking of a light weight set up on 4s to fly at the local club , easier to land since light using this drone motor. and play with some 5" props...
says it can do 700 watts , 47 A, Only query is will a regular airplane esc like 50 a or 55 will work on a drone motor like this?
Mike RC
Love it!
More stable than the Mini-Q you made?
Flown back to back, yes, the Xray is currently more stable than the MiniQ. Made me realize I still need to do some tweaking to the MiniQ, most likely shimming the motors down further to remove that last bit of speed-induced lift. The Xray will hold it's line at any angle when I let go of the sticks, it's probably the most dialed in plane in my hangar.
Using the same powertrain (1507 2700kv + APC 4.1x4.1 + 4S 18650 P28B) as the MiniQ, the Xray is a bit slower at WOT (by about 15mph), but is easier to launch. MiniQ is more stable at lower speeds and will gently hyperstall, Xray wants to drop a wing. Xray is also 710g AUW so that's not surprising.
Just picked up some AMAX Inno 1510 2800kv motors to try. These can run APC 4.75x4.75s at the exact same efficiency (on the bench) as the above setup, so betting these will give a higher top speed.
Hoping to get the MiniQ just as dialed in, but the Xray is the current fave.
3D Files: https://www.thingiverse.com/thing:6822378
You would probably be a bit better off with a lighter weight glass version of the X-ray. But in the end I don't know it would matter much. You would only save a little weight.
Can you post me a link to the motor?
why is ur plane? 710 gram ...it should be less than 500 gram based on the set up weight listed here...https://www.hyperflight.co.uk/products.asp?code=KNIFE&name=knife-racer-1m
Oh... do you have FPV gear on it? how much does the FPV gear weight?
Mike RC
is
@Wayne thanks for getting my account working and shout out @smirkracing2024 for pointing me over here!
Any word on when these things get back in stock? Since I didn't see an intro section might as well do that here since it's my first post--here in central AZ, we have a ton of space to fly in. Figured a 200mph pylon racer would be a great way to make use of all that space! Had a hopped up EF1 pylon racer that was doing probably around 130, and before that I had a scratch built Adrenaline Rush going around 100, which was terrifying just because of how small it was. Anyway, I'm ready for the next step up in speed.
As my username might suggest, I'm a 3D guy... we love tearing it up out here in the desert!
You wanna do my TP setup when we do get them in stock? That does 200 MPH and at reasonable amps too.
I'm not sure, I did look at that motor but it's 1.1 kW out of a 146 g 3300 Kv inrunner. I can take a Badass 2315 2300 Kv to 1.2 kW on 6s for only 76 g, and the outer diameter is identical to the TP2930 (literally identical to the 0.1 mm), and I'm all for saving weight where possible. It can back mount like Wayne's version with the DYS or it can front mount, I'm not sure which way you mount the inrunners?
Also, what size packs are you running in your hot setup?
PS I like the idea of having flaps on a hot plane like this (y)
@Jarron sounds awesome. I would be interested in that too.
And this would be a pylon racer, right? So perhaps 2 min of wide open throttle and a very small prop, like 5x5?
Or a different style?
