X-Lite rubber grip is worn. Need a fix, replacement, or cover.
frank26080115
The rubber grip of my X-Lite is a bit rubbed up. Is there a way to fix it? Or replace it? I'm looking at all the skins I can buy and none of them actually stick over the rubber part.
I see silicone wraps on eBay but I want that as a last resort since it ruins the look.
If you are refering to the rubbery finish on the outside of the radios, probably the only thing would be a new outer shell. Not a very easy swap, but can be done. Oneof the aftermarket skins might be worth a try, never saw one in real life.
