How do I get started? When I downloaded Wing Helper I came into the program with Version 1.7.1 ! First of all, the control icons are too small to read and secondly, I can't make any
thing happen.
Is there an earlier release that I should download that gets me started?
I'm using 1.71 as well and it works fine for me. I have a Windows 10 system using 1920x1080 screen resolution. All of the icons at the top should have a little context text that pops up when you hover over it with your mouse. Also, all of the actions with the buttons are available via the normal text menu on the top. You need to add a new panel on the first page and edit it to get to the meat of the program.
You have to click on one of the wing panels to edit it and then everything changes. I forget the exact one but it is in the left panel. Just select it and the it will let you begin to edit.
