Hey Mike-
Happy to help.
Let me start with, please do not run this large a plane on Spektrum. The quality of their RF is not suitable IMHO. Far too many nice planes crash every year do to Spektrum's old fashion RF. And trying to run their receivers on a better brand of transmitter, while possible, it is never a great idea. If you are going to use their receivers, best to use their transmitter too.
Yes, the X18 can do anything you would like. Each servo will be a seperate channel, but you can group them and mix them any way that you like. It is a little hard to explain when you are coming from a menu driven radio, but with FrSky you can do anything you like. Very powerful. Want to have 12 flap servos? Not a problem. Want each one to do something slightly different? Not a problem.
The RF system on Frsky radios always comes out on top when it is compared to other radio systems in the market. These tests are real world tests. This is one of the reasons FrSky radios are so popular.
Telemetry has been built into the core of every Frsky radio ever produced. Almost all of their receivers includes telemetry. (Only a handful did not over the years, and those were for specific uses.) FrSky offers more receivers than any other brand. They have receivers smaller than you pinky fingernail, and they have big power distribution systems and everything in between. They can include stabilization, varios and all are packed with more features and whistles than you can possibly need. Basically they offer a few different RF systems, here is a quick break down:
ACCESS (2.4ghz): Archer series are the "standard" receiver, I'd say about 85% of pilots are flying these. They are awesome, best bang for the buck.
Tandem (2.4 and 900mhz): All of the same great features as the ACCESS but with a back up 900mhz long range band should anything block the 2.4 band.
TWIN (two different 2.4): All of the same great features as the ACCESS, but this time with a backup modern 2.4 long range system.)
To define long range - Lets just say well beyond sight. Typically miles. The 900 has the advantage in being able to bend around buildings and other obstructions with ease.)
All of the above ranges offers many receivers to pick from. Some are teeny tiny for micro models, and others are dedicated for small or larger gliders, and then others have a lot more channels or stabilization to help your model fly smoother despite winds and turbulence.
All of these can be connected to a wide range of sensors to further expand their capabilities. Some common ones are monitoring battery voltages, temperatures, RPMs, fuel flows, vario, amps, etc.
It can be as easy or as complex as you like.
