Which 2-3 meter electro thermal glider for chilling out on a beautiful day?
With flaps that can hit the ground it is common place to lift them just before the plane touches down. This is something I have always done, and never killed a flap servo. I will admit I got lucky a time or two when I threw the flaps down instead of up, or was a little slow on the up command, but I rarely use an X08 on flaps as most of my planes are larger, heavier slope gliders.
When I'm using music wire for a control surface linkage, I like to use a small enough wire that it can bow if it takes a sharp hit. Saves gears and hinges. I for sure like to do this on combat models. A slight "V" bent into the wire can also act as a simple spring, but for flap, the setup Konrad shows in pretty clean and I have seen it in action when he flew here at the shop and landed with full down flap. Thought for sure his servos would be dead, but then he showed off the spring.
It is optional for sure, but probably well worth the time and trouble.
I combed around https://www.rc-network.de/ but could not find the thread.. I know they have it there somewhere.
Probably here :
There is an instruction PDF (in German of course) in there : https://sansibear.de/wp-content/uploads/2019/07/Sansibear-Django-Neon-Bauanleitung-v2.pdf
It is my favourite model , using it in F5J contests
Hi Avi! Looking good! I meant to get you those build photos from the manufacturer over the weekend, but those were on my work computer. Check your email in a bit.
I didn't think to put the spars in the vertical stabilizer. I wonder how important that is, as I am not super enthusiastic about trying to add them now.
How far do you think they stick through the stabilizer?
Probably here :
Interesting. These instructions just attach the vertical stabilizer directly to the boom without a spar, so I guess it isn't strictly necessary.
The sansibar video of the new version does seem to have the vert stab spars though.
I wonder if those are just to ensure solid attachment. I think my stabilizer would probably fail before the epoxy. They used CA in those instructions, which I don't think I would trust as much.
I'm not sure I understand what you are asking about.
Konrad points out that the vertical is a stressed skin structure and should be treated as such. This means the outer skin needs to be glued to the fuselage tube with a good epoxy and some cab-o-sil.
In looking at the pictures I think you are asking about the alignment pins? The carbon pins that exit the bottom of the vertical?
Did you already glue the vertical in place?
Photos of what you are doing will help us understand what you are referencing.
I already attached the stabilizer to the tail. With care, I could probably remove it. I could probably also use a pin vice to drill through and add the pins without removing the stabilizer.
  • In the build guide from WimH for the old Django they don't have any pins, so maybe they aren't necessary.
  • If the pins aren't necessary for rigidity, I could just add a reinforcing bead of epoxy and call it good.
BTW, is the boom supposed to remain removable, or should it be epoxied to the fuselage?
Below is from the photos that Jarron sent me they put pins in the vertical stabilizer.
Looks like a nice plane 🙂
I'd retro fit the pins by drilling from below, but I'm a belt and braces kind of person.💪
Martin
No pins needed. You could actually make things worse by adding the pins as you could pull foam away from the skins.
Yes a reinforcing bead of epoxy will do the trick.
Yes, the boom gets glued to the fuselage.
Glue the fuselage nacelle to the fuselage tube: Roughen the bonding surfaces of the fuselage tube and nacelle. Apply epoxy to the bonding surfaces. Screw the wings onto the fuselage nacelle. Slide the fuselage tube onto the nacelle. Insert the control cables into the nacelle. Carefully rotate the fuselage tube to align the main wings precisely perpendicular to the horizontal stabilizer.
Finished the servo connector holes and made wing bags today.
After drilling a pilot hole, I used a bit of a jigsaw blade in a pin vice and a file to finish the hole.
Screw head broke off while installing flap servo. Seemed like maybe a faulty screw. 😫
Removed servo and used a fine soldering iron tip at 200C to work it out of the print. Just pulled it by the top of the screw through the side of the print while trying to do as little damage as possible.
Then used a larger flat tip to reform plastic, dropped servo back in, used pin vice drill to remake pilot hole, removed servo, wet hole with a little CA to fill any interior gaps/cracks, and put screw in to distribute CA and keep it from filling hole completely.
Reinstalled servo and seems good enough. Sorry, didn't grab any pics.
Yeah. It was just one of the little mounting screws that came with the servo.
Everything is alright now. Nearly done with the build. It has been hard to find time where I can take up the whole dining table to mount wings to hold the plugs aligned while the epoxy cures. Same for attaching the tail. Finally got it done, so I'm in the home stretch.
BTW, for the wing connectors, I put the V+ on the outer pins, as I knew I had a 50:50 chance of getting the inner top/bottom pins mixed up. Worst case I would just have to flip the servo plug around.
From Konrad:
Yes, the Bowden tubes are encapsulated in the slots after their location is found using the 5mm or 6mm servo arms. I’d like to see that there be an undercutting of the wing skin to allow the formation of an epoxy bead between the lower skin and servo well liner (servo mount). Also suggest that the flap push rods be manufactured with over ride springs.
There wasn't enough distance between the servo and the control horn to do this if you build as intended.
I decided to not worry about it until I break a servo and then I will decide what to do.
I could have gone with a smaller gauge wire too, but will save that concern for later too.
@Wayne instead of making a springy link, what do you think about making a TPU control horn.
I could design it to be reasonably flexible and maybe even buckle at a designed load.
Edit: Maybe not buckling, which is could be catastrophic in flight, but I think that flexible/sprung control horn might be the way to go.
Well, Konrad will give me all kinds of hate texts for this, but I wouldn't really mess with the spring link either. I'm a simple guy, some SMALL music wire with Z-bends at both ends is all the more I'd do. And then lift the flaps before touching down. Call me silly. Simple is also good.
@Wayne do you guys have the right control links to fit these? The Dubro ones I have seem like a slightly different thread. I'm guessing it is a metric vs imperial thing.
I'm also thinking about clipping them and just doing z bends
Yes, the MP Jet Clevis should do the trick.
I'm guessing those are 2mm threads, please confirm, if they are this is what I would suggest one of the plastic units down towards the bottom of the page. You can see they have different pin sizes. 1mm vs 1.6mm to fit your horns.
