Hi guys,
What GPS module does the FrSky GPS ADV Sensor uses?
I am sure some of you may know this but just in case: every GPS sensor has a built in GPS module. The GPS module is the actual sensor that acquires the signal and process the geolocation. The most common manufacturers are U-Blox and Beitian. GPS modules vary in how many satellites can they lock and also how fast and accurate the geolocation information is generated. So I want to know which GPS module does FrSky uses in their GPS sensors. If you remove the shrink wrap from a sensor you will see the GPS module instantly.
Thank you,
Christian
Thank you,
Christian
