hotdogx
User
I recently successfully changed my Horus X10S RF board to the new version which has ACCST and ACCESS, and also updated the firmware. I am using GR6, G-RX6, and G-RX8 receivers. I have updated the firmware on the G-RX6 and G-RX8 receivers with the newest version of ACCST. I am running ACCESS on the GR6 and ACCST on the G-RX6 and G-RX8 receivers. Since upgrading I have run into an issue with the variometers on these receivers. The altitude telemetry works fine on all the receivers. The problem is with the variometer function. When the gliders are on the ground the variometers work fine, but as soon as the gliders are launched the variometer tone goes into a rapidly beeping, high-pitched sound. This is as expected, but after the glider levels out into normal flight, the vario telemetry continues to be a rapidly beeping, high-pitched sound, as if it is "stuck". I can do a reset and then the vario seems to be working normally again, but of course this then also zeros out the altitude which I do not want. I should note that previous to updating my Horus TX, the vario function on the GR6 receiver worked fine, and I have not changed/updated the GR6 firmware. And the vario function also worked fine on the G-RX6 and G-RX8 receivers prior to the TX upgrade. I suspect that the vario problem has something to do with the upgraded TX firmware, but I haven't figured out what it is. I looked at all the vario settings on the TX Telemetry setup and don't see anything there that looks like it would be causing the problem. I have deleted the sensors and re-discovered the sensors, but this does not help. Any ideas or suggestions would be appreciated.
