C
Camano
Guest
I'm looking for specific recommendations on how to bring my Dodgson Camano (built in 1991) into the 20th century. I want to replace the 72 MHz setup (channel 18, anyone?) with a modern transmitter and receiver. Here's my current wish list:
Some motivation / explanation for the items above:
1. The Camano has a mechanical mixer (AFART) that gives elevator / mixed rudder-aileron / flaps / trailing edge reflex (camber adjust) using just three unmixed channels and only three servos. It works like a charm, but it's complicated and I really do NOT want to try to rebuild it with new servos! (I did borrow a modern receiver and was able to confirm that these old servos did indeed work with it once I carefully convert to modern connectors.)
2. The 4-AA square pack is all that will fit.
3. No explanation needed.
4. Vario -- Besides the obvious, I think I would also enjoy being reminded of my old hang gliding days (and it would be nice to be able to program the sounds accordingly). Battery level -- I hear that digital drive to analog servos consumes significantly more power than the old analog drive did; will I be able to fly for a couple of hours on 4 AA cells? Signal strength -- Anyone who has flown long enough has had to make repairs (or get a new model) because of signal strength issues.
5. Neither DLG nor electric was really around in 1991, but they look like fun!
I'm already thinking FrSky (which is why I'm posting here); how do I decide which transmitter and receiver to get? Other info: I'm willing to pay for upgrades that I will enjoy if someone will explain them to me
, I haven't ever done any contests (I know very little about it), but just joined a local club that does a lot of that stuff; I would prefer battery recharging to be straightforward (i.e., not removing battery pack).
Are there other questions I should be asking?
Thanks.
Darrell
- Continue to use my existing Airtronics analog servos.
- Use a "square" battery pack for the receiver (no bigger than 4 AA cells).
- Very good range because there are times when I may have the opportunity to safely fly at very high altitudes.
- Telemetry: vario, battery level, signal strength
- Easy to add more receivers (other models) in the future.
Thanks.
Darrell
