update firm ware
F4u1adave
hello new to this ok here we go i have the taranis x9d plus date 3-25-2015 my question is whats the best firm ware to put in it its never been updated or have not used it since i bought it do to i lost both parents in two years an been to busy to fly my giant scale birds so now im in it for the long haul now an wanting to learn every thing i can from programing the radio i bought the open tx book here from aloft hobbies im just wanting to no what update firm ware i need for my radio an my RX im only using 0nly the X8R recivers i have just two of them at thr moment so if one of you awsome guys out there can help with this it would so awsome this radio will be used in giant scale an glow planes an maybe a edf jet thanks guys an have a wonder full flying day.
It depends on what version is on the radio. You will want to update in steps through the major versions all the way to current, once you hit the 2,3 series you can go directly to the newest release.
The taranis is the 2015 version an never had any up dates ibought the radio an never used it do to family things now im back into it an wanting to use it as my main radio for all my planes glow an giant scale i guess what im asking is what all firm wares do i need to put.in the radio to be up to date an i only fly planes
Actually, you will want to open up that manual and check out the section on updating the firmware in the radio. It will have a special section just for your older radio, you do not yet have a normal bootloader on your radio, so you have an extra step to go through. You will only need to do it once, but you will be able to update to the current version in a single update. No need to go step by step since you are not attempting to save any model memories in the radio. :)
The 'manual' your referring to is the one sold here at Aloft for the X9D+? My radio (purchased here) is old with aprox. 30 models in memory and on version 1.1.02 ! I too fly only fixed wing airplanes with out any issues. Will the 'manual' walk me through this update as well? Will Aloft's preloaded SD card for my 'plane jane' X9d be of any benefit ? How will such an upgrade effect the receivers already in use?
You can update OpenTX at any time, and yes the manual has a special section for the plane jane X9D update process as it is a bit different the first time you do an update. I do recommend you do this update as you will gain a number of new features and compatibility with the new receivers and sensors. During this upgrade of OpenTX, you have a very good chance of losing your existing model memories. You have a VERY old version of OpenTX on your radio at this time.
If you only update the OpenTX, then your existing receivers will be fine. No changes needed.
If you also update your RF firmware (ACCST V2) then you will need to also update the firmware in all of the receivers. It is a bit of a pain, but probably worth doing. Also note, all new receivers we are shipping are going to be on V2 firmware, and they will not talk with a V1 radio. So you either update the radio to V2, or downgrade the new receiver to V1.
The Pre-loaded SD card might help, but you can easily source all of these files yourself from the FrSky website. We just offer the cards to help folks out a bit. Since your radio is so old, out quick and easy update via the SD card will not work for you, so not much benefit to the pre-loaded card for your application. Sorry.
The thought of loosing 30 some models makes me cringe. I'll pick up the manual .. I should have one anyway. I have no complaints with 'plane janes' performance 'as is'. Since I've recently acquired a QX7 (ACCST) and have updated it to 2.3.14, as I acquire newer receivers I'll fly those on the x7.
Once again Thanks!
Using Companion it is possible to move models from one radio to another. The only missing functions may be switches etc not supported on the lower cost radios.
Henny, the main issue he has is he has a VERY old version of OpenTX on his X9D. They really are not compatible with current versions of OpenTX. He could possible update slowly by bringing the model memories up through many of the old versions of Companion allowing it to convert the model memories at each step, and he might be successful. (You could do the same by installing the many different updates to the radio, but think Companion would be faster and easier. For someone that has not done an update or used Companion much, this would be pretty difficult.
Ok wayne the radio was bought in 2015 an what ever firm ware was in it then is whats in it i have never used it since i bought it new no planes or memory is in it so i guess my question is from 2015 firm ware till now do i need to i stall each firm ware to the last up date firm ware i do have the book on i bought it from you guys aloft hobbies an do i need to do the same to my recivers i just want to put the firm ware in it right i dont need no crashes do to signal lost on my giant scale birds.so do i have to put each firm ware up date in to the latest one.thanks dave an .how much is the newer taranis x9d radio. I have the one with 3 buttons on both sides.
Nope, you can jump to the current version of OpenTX. Follow the steps in the manual for the older X9D that you have.
You will also want to update the RF firmware on the transmitter and all of your receivers since you will be flying giant scale planes. This is a little more involved.
You can find the current transmitter pricing here:
If you like, we can update the receivers and transmitter for you.
Hello wayne whats the charge for the update firm ware for radio an rx an do i have to stick with the older rx if so whats it look like for them to be made in time wise before they become discontinued on the rx.
If you preform the firmware update yourself there is no cost. The receiver firmware is available here from the FRsky webb site https://www.frsky-rc.com/download/ and the TX firmware is availble here from the developers Ethos Github webb site. https://github.com/FrSkyRC/ETHOS-Feedback-Community/releases.
If we do it for you, the biggest expense will be the shipping. :( Think we charge $15 for a transmitter and a couple of bucks per receiver. While we have the transmitter here we usually go through it and make sure things look good and are in working order.
