Check the file you flashed, you should be using UNI_x4r_84sm.frk not UNI_xsr_84sm.frk.
All works OK for me with ETHOS 1.6.2EU.
Mike
Thanks Mike but I checked my Taranis (which I used for the update) and the file in FIRMWARE is UNI_x4R_84sm.frk
I should check that I did not inadvertently use the x8r file which is below the x4r one.
EDIT I have re-flashed the UNI_x4R_84sm.frk and I'm now getting the correct voltage. Thanks for advice.
As an aside, on another model with an RX8R-PRO installed, using my X18 (on Ethos) if I check the Telemetry signals for RxBat, it is giving me the correct voltage but if I stir the sticks vigorously with the radio say <5ft away, the battery voltage signal ceases and the radio reports "internal module telemetry lost", the volts number stops changing and turns red. I have to switch off the Rx to recover. This did not seem to happen with the Tx 30ft away.
I have picked up on a problem with RxBat on the RX8R-PRO, I have a fix tested for that, it may be the same as your problem.
Do you lose RSSI as well as RxBat? Every telemetry packet has one of RSSI and RxBat in it, alternating which is sent.
I haven't released the fix for the RX8R-PRO as I'm adding the ACCESS protocol to UNI.
Mike
fore Frsky sends out newly purchased radio, why doesn't Frsky update it so the new buyer doesn't have too and run into all kinds of problems?
Typically FrSky will do a very large production run for a given radio type. This run is probably enough to meet global demand for anywhere from 6 months to several years depending on demand for tha version and that color. They do install the current stable release at that time. It is boxed and stored until purchased by individual or distributor. If a distributor, then it will continue to be stored until sold. You can tell how long ago your radio was built more or less based on the version of firmware installed. (FrSky may skip minor updates at the time of construction.)
Now onthe software side of things, frSky does not have a hard set firmware update release schedule. They release when things have progressed and there is enough reason to release. This could be every few weeks, or every few months, but it is pretty often compared to other companies. They are very software based and like to add features and fix bugs. It can be a little trying to see a bunch of updates, but it sure is nice to see the firmwares mature and add features.
Other radio companies are very poor about fixing well done bugs in their radios. Futaba for example had known bugs, not only did they never fix the bugs in the production life of the first model of radio, but they used the same basic software in later versions several years later and they still had the same bugs.
Futaba is overrated, in my club most people fly with Futaba but most do not even know how to program things that are basic things in OpenTX/EdgeTX/Ethos. New rooky members are told to buy Futaba and they mostly keep flying with it, not knowing there are easier (and cheaper) systems out there.
However, UNI is what FrSky should have created themselves. Just one firmware that deals with ACCST v1/v2 and FCC/LBT.
There's also people with Spektrum, Jeti, Graupner, Multiplex, Powerbox and FrSky (which I use myself). And some 3D heli-pilots fly with Mikado VBar. So, it's not only Futaba. :)
Hi Guy's
I have a Frsky x10s TX running Ethos 1.5.19,trying to load and run the following software
UniActivate,Unistatistics and Unisetup.
Which files do I use and how do you get them to run on my TX
Many Thanks for your Help
Dave
The first post of the release files thread now includes a test version of UNI that supports the ACCESS protocol as well as ACCST.
On older receivers (e.g. X8R) check if you still need low and critical RSSI levels set to 45 and 42.
To use ACCESS, simply power the Rx on with the button pressed and register the Rx.
With the button pressed at power on, the Rx will detect an attempt to register in ACCESS mode as well as binding in one of the ACCST modes.
The ACCESS implementation does not support the SHARE feature, but does support Dual Bind, just register the Rx to two transmitters.
Please TEST carefully BEFORE USING TO CONTROL A MODEL.
Mike
V86 on older receivers was not handling SPort devices, V87 fixes this. Newer receivers still use V86.
Mike
The S6R was reporting as a S8R, and registering a default name of "US8R".
I've updated V87 for the S6R to fix this.
Mike
I have 3 RX6R receivers and 4 G-RX6 receivers. I was able to flash the UNI firmware (UNI_RXxR_GRXx_85sm.frk) to 2 of the RX6R receivers and 3 of the G-RX6R receivers. The 2 RX6R receivers that were successfully flashed, bound to a 4 in 1 module, and I was able to use the activation procedure. The G-RX6 receivers were different. After flashing, they easily went into bind mode with the 1/2 red blip. When binding, after a brief red/green light conversation, they showed the flashing green light. However, when I unplugged them and then reapplied power, I got a red light and a flashing blue (just for fun, if I pressed the bind button again, it went into bind mode with the 1/2 second blip red light). I tried the procedure multiple times and got the same results. Has anyone had a similar problem? Thanks!
Is the red LED solid with the blue LED flashing or are they flashing alternately?
Do you have a different Tx/module you could try binding? Maybe something to do with the unique ID of the MPM is causing a problem.
What is the timing of the flashing blue LED? There are two places where I do flash the blue LED, both are fatal errors that are not expected to occur, and the blue LED flashes at different speeds for them.
Have you tried flashing with FrSky firmware?
Mike
Thanks, Mike. The red light is solid and the blue light flashes less than once per second. I turned off the radio after the blue and red light came on and the blue light went off and the red light started a slow blink.
On the G-RX6, the blue LED comes on when you first power the Rx on. This is done by the bootloader. From your description it seems the Rx is rebooting when it is receiving data from the Tx, not something I've seen before!
What protocol are you using when binding (V1/V2, FCC/LBT)? What other settings do you have on the 4-in-1 (e.g. RxNum)?
I've just checked my G-RX6 using ACCST from my FrSky X9LiteS and it works correctly.
Things to try to help pin down what might be happening.
1. Flash FrSky firmware and check if all works correctly.
2. Flash UNI V83 (its on the third post of the release files thread).
3. FLash V86 that includes ACCESS
Mike
Thanks. Per your first reply, I tried a different 4 in 1 module and had the same result. The odd part is the RX6R receivers work on the 4 in 1. It's only the G-RX6 that doesn't. I tried the G-RX6 on a Taranis X9D+2019 and had the same result. The one RX6R that I couldn't flash with UNI has ACCESS on it and works perfectly with the Taranis. The Taranis has the last version of IRSM (2.1.10) and the ACCESS version is 2.1.8. Unfortunately, the G-RX6 will not bind with the Taranis on ACCESS at all. I will try the UNI83 and V86 with ACCESS. Would a short video of the flashing lights help?
OK, I tried V83 and V86. I had the same result on 2 different radios when binding on D16. On V86 and ACCESS it would not register. While I'm sure it is possible for a receiver to be kaputt, it seems unlikely that all 4 G-RX6 receivers would be extinct at the same time.
Matt
