Hi
It looks like the UNI firmware could help me but I would need your feedback, I read a lot but not sure of my conclusions.
I am using X6R/X8R/X8R Pro and would like to add extra servos above the PWM physical outputs, respectively 6 and 8 channels, by using the SBUS port.
If I need ony one extra servo, the UNI firware allows to use the SBUS port as an extra PWM output, which is awesome.
Now if I need 2 extra servos, I do need to use an SBUS to PWM converter. Lets use X8R as an example.
First option is to use the Frsky SBUS to PWM convertor. While the FrSky SCC (Servo Channel Changer) is discontinued, I saw an Windows app using the Frsky STK to set the channel ID per PWM output, thus having the 4 extra PWM output on CH 9 to 12 (
https://www.rcgroups.com/forums/showthread.php?4776841-SBUS-Channel-Changing-(FrSky)&perpage=20). Am I correct ?
Second option, take a 4 CH SBUS-PWM converter from AliExpress but it looks like they are "hard coded" to read the SBUS id 1 to 4 only. So the issue might be that the converter will take the id 1 to 4 on the SBUS, thus duplicating the physical PWM port 1 to 4 of the receiver, and therefore not adding 4 extras PWM output.
(on some 8 CH converter, you can choose 1-8 or 9-16 by solder a shunt, but theses converters are much bigger and also more expensive for just 2 extra channels).
Can UNI Firmware remap the physical PWM output of the receiver to channels 5 to 12 ? (PWM1 - CH5, PWM1 -CH6 etc) so that CH1 to 4 will go to SBUS and the converter and CH5 to 12 to PWM1 to 8 physical output of the receiver ?
Thanks for your advise.
