I got a Walkera G400.
Unable to bind with OpenTX.
With a receiver called FCS400, select DEVO (7ch) as the protocol geometry dash lite.
Anyone know how to bind it?
Your Walkera G400 comes with an FCS400 flight controller and typically uses Walkera's proprietary transceiver system (DEVO protocol). This is why you cannot connect directly to radios running OpenTX (e.g. Taranis, Jumper, Radiomaster). So you should use a radio with an MPM that supports DEVO. You can then bind the FCS400 by selecting the DEVO (7ch) protocol in the menu.
