Trying to update an old X10S radio to ACCESS - upgrade kit and firmware problem
Kiwi0ne
Hello all.
I have a new OLD Horus X10S that has been sitting unused for 4 years.
I recently bought the Upgrade kit and changed the ISMR and Para module.
I have a new Archer R4 as well.
I went to update the firmware using version 1.3.07 with iXJT v2.1.0 update, dated 2020-03-24.
Copied the NEU version of the firmware in the SD card and followed the flashing procedure.
The firmware probably updated well but now the radio is sitting there with Updating IXJT module, this will take a few minutes and it’s been like that for a long while. I tried powering it off and back on and that message appears again.
I have probably bricked the radio?
Any help would be appreciated.
Did I use the wrong firmware?
Followed the wrong procedure?
Are you using opentx as the radio firmware, what is the version number.
If you have installed the upgrade ISRM kit are you sure you have installed the para board correctly, its not a beginners soldering experience. So to run the radio with the ACCESS kit the new RF module needs ISRM firmware not iXJT. Also needs a late version of OTX firmware.
So where are you at presently.
Henny
