Trouble shooting failing elevator servo
Konrad, I asked the question about refresh rates in my post. How can I accidentally make 9ms rates during the binding process without using jumpers...? Am I missing something?
I don't know about your radio but I thought that the refresh rate was defined in the TX at the time of binding, not at the RX with jumpers?
Noise on the lead will act like a very high refresh rate turning on the amp at very high frequencies.
Are the antenna introducing noise on the elevator lead?
See noise issues in this thread?
Some of what you loose with the economy servos is input filtering
You've got me thinking and learning more... I'm gonna keep gluing this plane together and experiment.. Great lessons learned..
Going to swap out the Elev and Rud servos for higher quality servos to see the the issue happens again. I'll also, rebuild the model on my X9D+, just for kicks. Just to make sure I didn't goof anything up on the refresh rates...
Since I got back into this hobby in Sept. 2020, after about 17-18 years away, I've been building like crazy. I may build 2-3 foamboard planes a week for me and my flying friends. My higher end builds that require more time and effort (complicated FT Foam with FPV gear or Balsa (rubberband to elec conversions) I use much better gear or at least its more expensive. Its all made in China these days..
I think your comment about cheap servos and input filtering could be the issue though. I was reading that thread about jittering servos and this plane as a servo jitter issue.. The odd thing is, this is the 3rd identical plane I've built with the same gear (I've upgraded this ESC/BEC5A, while the others are still using a 3A BEC). Those other planes are still flying with no issues.. This plane however gets the jitters, the others don't....
Question: Is it possible for the rudder servo to be causing interference to the Elevator servo? They are next to each other and their wires are running along side each other in the fuse.
In theory yes, the magnets from the other servo could have an effect. In practice no.
Now I've seen much worse antenna installs. But try separating them. Maybe move the cross one half way towards the rx.
Tell me what you make of this.. Turn your volume up to hear the jitters
  • Servo Jitters.mp4
    27.9 MB
Typical noise on the leads with an analog servo. Your finger is acting like a ground plane killing the noise. I notice the leads are ribbon not twisted wire. This noise is driving the amp on at far too high a rate which results in the amp (power outputs) burning up, as they are not rated at this high a duty cycle. Try braiding the three wire +-s together. Or look for what are known as noise traps. I like using two CMOS inverters. (This is an old analog trick from 50 years ago). As I recall the 7404 was a quad chip, you could get enough of a circuit to drive two servos per chip.
I've been know to build them by just hard wiring to the pins, no need for a PCB.
I see that there are enough inverters to filter 3 servos per chip
Please note the proper twisted leads. Flat ribbon is only beneficial for robotic assembly. In the real world they are crap! To cut down on manpower most servo OEMs are using flat ribbon. but they add extra layers of noise protection. Well, the higher quality OEMs do.
LOL
The connectors will cost more than your servos!
Did a quick braiding of the servo wires and extensions (the braided extensions I had on hand for way too long....). The jitters are almost completely gone.. A little every once in a while... But noticeably different. I'll continue to repair this plane and see if the braided wires eliminates the issue.. If it piles in again, I have some nice digital servos waiting in the wings for its replacement build.. But, this is a great experiment and I'm learning a great deal..... Appreciate the teaching..
