Wow I knew Opentx was "Free Form" but this is incredible - I have enough trouble concentrating on the natural trims - can't imagine remembering this capability let alone using it. I dips me lid to those that can.
Cross trims
Posted on July 4, 2014 by John Case
A radio configuration for using a free thumb to adjust trim. For example on a mode 2 radio the right thumb could set rudder trim using the aileron trim switch and the left thumb could adjust aileron trim using the rudder trim switch. Same idea for swapping throttle and elevator trims.
Throttle Trim Idle Only
Posted on July 7, 2014 by John Case
Restricts trim input to only the idle portion of stick throw unlike the usual offset with affects both ends of the throw. Useful in wet fuel set ups to avoid overdriving the throttle servo. Useful for electric power set ups to keep the prop turning at idle throttle without changing how ESC views the upper end of the throttle.
Without testing, am I right in assuming that despite setting a maxim/minimum throw in 'outputs' the conventional trim that's aligned to channel could override that set value? I know that Graupner (MX22) limit throttle trim activation to the lower end of travel but don't know if it can exceed the idle set value.
These forums are meant to be educational - this episode has been good for me in that regard.
Thanks
Cross trims
Thanks
