Flight report.
With the aileron to flap mix set at 20% using Mike Shellmin's Open TX templet "E-Soar Plus V3" I now get good aileron (roll) control.
http://rc-soar.com/opentx/setups/esoarplus/index.htm
The Samsara with the CofG set at 91mm (95mm April 2019) stalls straight ahead. I also don't need any motor to elevator compensation with the CofG at this setting. The rudder roll coupling is very benign making cross controls (rudder aileron) very nice while flying tight thermal coring circles.
The elevator response is very nice!
When coming in under full crow, with the aileron flap mix set at "0" (dead) in full crow the roll response is now good. (I still like to manually add rudder).
Set up values are as follows () factory recommended values:
Elevator:
Up, 12mm (17mm)
Down, 17mm (17mm)
Rudder:
50mm (50mm)
Ailerons:
Up, 22mm (25mm) [24mm up April 2019)
Down, 11mm (14mm)
Crow, 13mm (18mm)
Flaps:
Aileron, Up 10mm, Down 8mm (N/A) [10mm up&down April 2019]
Reflex, Up 3mm (3mm)
Camber, Down 4mm (5mm)
Crow, Down 80° (70mm) [Down 90° April 2019]
Flap servo arms 12mm long
Aileron servo arms 6mm long
Thrust lines are perfect when centering the firewall to the factory cut nose opening.
The airfoil responds OK to camber changing. Reflex response is not as great as I've come to expect with other popular airfoils.
The long fuselage magnifies, makes it easy to read, the aircraft's attitude changes to the air's movement. It is well worth the added mass needed to balance that tail, that is way out on the end of the tail boom! At 2.06KG (1.965 kg April 2019) the Samsara is no light weight by today's F5J standards. But she is very responsive to the air. That is what we are really concerned with when we talk about wing loading. I'm really liking the 1.8 meter fuselage compared to the standard 1.5meter fuselage that is standard in this class of model.
Airframe report.
Like I said I really like the fuselage. It is long and more than adequately reinforced with carbon to make the boom stiff. There is extra carbon around the elevator rocker opening, this opening is not the week point in the fuselage. The fuselage weak point is in the battery opening. Add some carbon tow hoops that span the fuselage seams. With the tail post installed the vertical fin is rigid making it more than adequate as a mounting platform for the tail servos.
I like that TopModels has left adequate flange material around the wing and battery openings to allow one to size the flange as we see fit. I choose a 5mm wide flange as there is a lot of stiffening carbon to be found just under these flanges.
The fuselage comes with the elevator rocker pin bore pre drilled. Also the wing hold downs are glued in at the factory but not pre-drilled for the hold down bolts.
(The fuselage is why I purchased Samsara).
The canopy should not be made of carbon in the modern age of 2.4 gHz.
The wings are a mixed bag, but overall more than adequate.
My main complaint is that the wing hold downs are misplaced by 2mm or 3mm forcing one to have to place a threaded insert dangerously close to the fuselage side in the wing fairing.
I don't like rib cap strips They just add work during building of the wing. The film covering actually offers more than enough lateral support to the rib. I hope TopModel gets rid of these. The labor credit from the removal of the cap strips should be applied to making the ailerons hollow.
The bottom of the wings (transparent covering) should have a lot more color to aid in high altitude visibility.
The glass wing joiners are far too heavy for this class of glider!
The spar is great! It is made up of 2 spruce spars with a full width shear web between them. On ether side there are 3mm shear webs that come up fore and aft and are glued to the side of the spruce spars. These side shear webs are reinforced with 50gram glass cloth to keep them from splitting as the wing flexes. I forgot to mention that there are also 0.3 thick carbon strips just inside the spruce spars!
Now my particular kit appears to have had a soft center section wing panel. As shown by the center panel going into flutter far too early (less than double the stall speed). I think most of this can be attributed to the poor glues (hot glue) used to assemble the wings.
My rudder had the hard point misplaced for the rudder horn.
General quality issues.
The holes in the control horns are too small for the supplied clevis pins. Wing hold down through holes are misplaced, The film covering over lap is too large. The wings are built with soft hot glue, and too much of it at that (The spar looks not to be built with this glue). Wing joining rod made from the wrong material (heavy). The canopy is made out of the wrong material. Hard point for rudder horn misplaced.
Now comes the difficult part. That is training the owner/pilot to get the most out of the Samsara
Elevator:
Up, 12mm (17mm)
Down, 17mm (17mm)
Rudder:
50mm (50mm)
Ailerons:
Down, 11mm (14mm)
Crow, 13mm (18mm)
Flaps:
Airframe report.
