I also have the elevator servo installed under the wing. This is a very easy simple setup with light carbon 6mm tube. Quality Savox servo. Zero slop in the system.
Next time I order rc stuff, I will add the 8mm carbon wing joiner in my order.
I did setup with EWD 1,5-2°.
But I'm still a little bit up in the elevator trim. (14 clicks up on Spektrum TX).
Maybe I can move the cg more aft (but I'm happy at 90mm) or the 14 clicks up trim is needed to compensate the negative flap position in flight due to slop in the servo. Only way to find out is to install a mini camera on the wing.
Tomorrow I'll check the 20mm distance at the elevator bed to compare with your glider.
