Ok, did some work early morning.
Installed the 3s-3000mAh lipo and balanced to glider to 90mm cg.
It needed about 15gr of lead attached to the front of the lipo to arrive at 90mm cg.
AUW is now 2050gr.
Also added strip of thin tape on the wing joiners. Only the part that goes into the outer panels.
This reduces 1/2 of the play at that area.
Programmed flightmodes an a 3 position switch:
- speed (flaps and ailerons 2mm up)
- cruise (flaps and ailerons at neutral)
- thermal (flaps and ailerons 2,5 mm down)
Didn't change my spoiler setup.
Ailerons start moving up when spoiler stick is at 50%.
So the first 50% of spoiler does only affect flaps.
In thermal I can use the first part of the spoiler (0-25%) to get some extra flaps down.
This worked very nice during earlier flights.
The only thing I changed is the spoiler-elevator mix.
Gave it some extra elevator down mix for the new 90mm cg.
Yesterday, moving from 72mm to 77 and 80mm, the down elevator mix at full spoiler was not sufficiant.
The glider pitched up to much.
I can still use the 3s-5000mAh lipo for more forward CG positions: 77, 80 and 84mm. (see picture)
Weather is fine today with no wind. I'll fly this afternoon and report later this evening.
Fingers crossed!
