Lol, You are correct I could build a modlie like this out of balsa.You need to stick with balsa models where you have more control over these things.
Hank
But that's not the point. The point of a molded model is building a model with high fidelity to the airfoil. Molded models allow the manufacture of airfoils (wings) that wouldn't be practical in say balsa. TJIRC with these Magnus models is NOT producing a very good set of wings. I point to the discontinuity of the airfoil in that not only can you see the substructure but you can actually feel the spar! Also the thick trailing edge is just lazy! These issues aren't a Ferrari vs Ford thing, but rather go to the core reason why we buy molded models "Its the airfoil stupid".
Then we have the quality issues jabbing the trailing edge with a screw driver, just stupid! The gross 0.15mm deep dimples in the flap (unacceptable). It looks like these came from improper cleaning of the mold as the paint follows the dimples. Then there is what looks like a dry lay up. NONE OF THESE ARE OR SHOULD BE PRICE POINT ISSUES. We as modelers that know what we are looking at, need to inform the buying public as to what separates the moldie from the bagged balsa wing (it's the trailing edge). Also the OEMs need to know that there are folks taking note of the quality of products!
Price point issues would be like the paint finish, masking and over spray. To my eye this is fluff and has no bearing on the suitability of the model. (BTW; TJIRC is getting much better at this with each production run) Also the added accessories like the servo trays these can lead an unsuspecting modelers into a trap. For example the little tray offered for the elevator servo will not support the nose. In fact it will add a stress riser and allow the nose to fail prematurely! The wing servo trays are horrible in that they are just shy of being burned charcoal briquets. I tried to point this out to help the OEM save their laser cutter from premature failure. At this price point I wouldn't expect a carbon stab. Or high quality hardware ( I'd like OEMs to leave low grade hardware out of the accessory package).
I think Jeremy mentioned the Prodiji. The ones I've seen are fantastic ships but are shy a flap. For $650 I didn't want to engineer a second flap. At that price point I'd have gone for the dated mini "T". I actually like that the OEM for the Prodiji did NOT put any emphasis of finish. This leads me to think that what resources he had were spent on making a solid model. Love the stand way back comment from Ed(?) on the Magnus !
I choose the Magnus over the mini "T" as it looks to be an advancement in aerodynamics over the mini "T". Take a look at the wing shape. But I failed to take a look at the quality and manufacture of the Magnus that negates these modern features. The fouling of the airflow over the wings (spar bump) and those gross oversized thick trailing edges result in a wing that might as well be dragging a 12" Estes rocket parachute!
I'm thinking of just adding 200 grams of lead to each of the wing tips and just DS's this crap. There really is no point in trying to make a silk purse out of this sow's ear!
