Well respected, hum. Well marketed, yes.
Most will agree that the OS FSR might be the pinnacle of the OS sport engine. She sported Schnuerle porting and a rather good auto-mixture carb. In the sport arena she was competing with the baffle K&B 61* with Perry carb. Or the Fox Hawk and Eagle engines with their non-standard butterfly carbs. The 15% premium in price over these engine was well worth it for a sport engine.
Crashes or sudden stops of the crankshaft would give me cause to look at the bearing in more detail. I put little value in how the bearing “feels” in an unloaded state. I look for irregularities with the bearing while lightly loaded axially and radially. I’ve seen far too many engines damaged while trying to replace bearings. I usually make up a set of bearing tools (mandrels) to allow pushing the bearing without needing to go through the rolling elements.
I see with the term "Tuned Pipe” that you and I were looking for more than a sport engine with our FSRs. And this is where the OS FSR fell flat on its face, compared to the European engines like Rossi, Super Tiger, Webra and a host of other brands. While the schnuerle porting did add a lot of power over the baffle sport engine. In and of itself this was not enough to make the FSR pull the pattern plane with the authority we expected from a piped 10cc engine. The 15% discount against the ST and Rossi sure was seductive. But when it came to the objective measure of the power to turn the prop, it was clear the OS FSR was a second tier engine to the Italian Stallions with their inflight mixture control and true ABC P&Ls.
This brings up a sore spot with OS Engines the corporation, OS Engines was practicing deceitful marketing with their term "ABC type” to identify their ringless nickel plated P&L technology. After about the 3rd gallon of fuel we sure learned the ABN (AKA, ABC type) was no match for the true hard chrome ABC P&L found in reputable engines.
Yes, I still have a few OS FSR where I tried to make a silk purse out of a sow’s ear with the use of Shadel/Nelson true ABC P&Ls as marketed through Performance Specialty.
*The Lee Custom K&B 61 could run with the OS FSR and many other sport schnuerle ported engines. But the use of a pump and pump carb put the Less Custom outside the area of sport engines.
BTW; I think the CMB 60 is the epitome of the short stroke 10cc Pattern engine.
