The Aerodynamics Channel.
Hi Guys, following a valuable suggestion by one of the wonderful Aloft firum contributors, I thought I'd kick off the Aerodyanics channel - a place were averything to do with hot air can be politely discussed.
Lets see how far we get.
OK, that done I'll start with a topic often mentioned here which is SPIRAL STABILTY:
One thing we should know up front is that Spiral INSTABILITY most often occurs on full sized powered aircraft that are making flat turns. Unless, possibly we are talking about scale or thermal soaring model applications, then this effect is actually quite a rare occurrence for slope models.
So here goes: This is a really simple explanation, written very much in non-math terms that I stole from "Aerospace Notes" the internet. I like it and so have taken the liberty of putting in some comments based on our slope flying models.
Quote:
What Is Spiral Divergence?​
Spiral divergence or spiral instability is a condition where an aircraft is directionally very stable, but laterally (JH: In Yaw) very unstable. It is characterized by low angle of attack and high airspeed. (JH: Woo - sounds familiar?) When the lateral equilibrium of the aircraft is disturbed by a gust of air and a sideslip is introduced, the strong directional stability tends to yaw the nose into the resultant relative wind while the comparatively weak dihedral lags in restoring the lateral balance. (JH: Dayum - we fly in a constant side gust - like on the slope!)
Due to this yaw, the wing on the outside of the turning moment travels forward faster than the inside wing and, as a consequence, its lift becomes greater. (i.e: A flat turn) This produces an overbanking tendency which, if not corrected by the pilot, results in the bank angle becoming steeper and steeper. At the same time, the strong directional stability that yaws the aircraft into the relative wind is actually forcing the nose to a lower pitch attitude. (JH: This is especially true of a V-Tail configuration) A slow downward spiral begins which, if not counteracted by the pilot, gradually increases into a steep spiral dive. (JH: On the slope we never have the time or the space below the aircraft to allow this to happen naturally - but in flat field thermal conditions - it could) Usually the rate of divergence in the spiral motion is so gradual the pilot can control the tendency without any difficulty.(JH: If Spiral Instability seen at all on the slope, this effect is so under-dynamic that its unlikely even to be noticed by the pilot)
Many aircraft are affected to some degree by this characteristic, although they may be inherently stable in all other normal parameters. This tendency explains why an aircraft cannot be flown “hands off” indefinitely. A spiral divergence is not a type of spin because neither wing is stalled. In a spiral divergence, the aircraft will respond conventionally to the pilot’s inputs to the flight controls. JH: Many references on design of full-sized aircraft recommend keeping the aspect ratio lower, and the fin area small to minimise this possible effect.
Example – Spiral Divergence:​
For example, let’s consider a large finned aircraft with no dihedral. In this case, when the aircraft is in a bank and side-slipping, the side force tends to turn the plane into the relative wind. The outer wing travels faster, generates more lift, and the airplane will roll to still a higher bank angle. No lateral stability is present to negate this roll. The bank angle increases and the airplane continues to turn into the sideslip in an ever-tightening spiral. Unquote.
spiral_divergence
Here is another exerpt from 'Aviation stock exchange': Again it references flat turns in conditions that will not often be found on the slope but again could be found in flat-field soaring.
Quote:
One of the primary causes of spiral instability is the fact that once a turn begins, the outboard wingtip is moving along a larger circumference and therefore moving faster, and tending to produce more lift, than the inboard wingtip. (JH: i.e in a flat turn) So the bank angle tends to increase. Keeping the wingspan small will minimize this effect. Obviously, this is a trade-off and other desirable qualities are sacrificed.
Re dihedral-- the inefficiency due to more wing area being needed to get the same amount of vertical lift component is rather minimal. The more significant negative effects of dihedral include a excessive slip-roll coupling that creates excessive roll torque during an intentional slip (eg crosswind landing), bad effects in gusty crosswinds, poor roll response to aileron-only roll inputs, and a tendency toward "Dutch roll" yaw-roll oscillations.
Keeping the vertical fin small will help allow enough sideslip to allow whatever dihedral is present work as effectively as possible to help minimize spiral instability, but obviously this is a trade-off as well. Unquote.
JH Conclusions: For a fast sloper the Spiral Instability effect is quite unlikely to be seen. Therefore, keeping the aspect ratio (wing span) low and the fin area small would not generally be included in the designers tool box.
I'll be putting more stuff up as time goes by - got questions?
Fire away!
Here is another small write up I did in another thread on twist wings models in answer to a question posed by email. As I design these big model planes (Drones) for living it was a pretty good fit, and it also deals with the issue of spiral instability, as described above:
I hope its interesting.
Why does the Predator Drone have an INVERTED V-Tail?
I'm sure a lot of people have noticed the inverted V-Tail on the Predator drones, but wondered why the larger Reaper does not have this feature and instead sports an upright V-Tail (Actually they are tri-tails as both have a protruding downward-facing electronics fairing)
The first thing to realize is that the odd-looking inverted V stabilisers are in fact all-moving "Ruddervator" controls and not just pitch controllers. On a UAV of the Predator's smaller size, there are in fact several advantages to this configuration:
  • A ruddervator placed beneath the CG, as on the Predator, will roll the plane toward the direction of yaw instead of away from it as a top-mounted rudder would, thus aiding prevention of spiral instabilty. This allows for wide, stable smoothly coordinated turns using only the rudder. Ideal for taking a looksee.
  • As The Predator would not normally make violent manoevers, and in fact its functions benefit from a stable flight path; this "rolling rudder/elevator" behavior is effectively all the aircraft needs in terms of roll and pitch control. In this case the ruddervator surfaces can be the only control surfaces, thus dramatically simplifying the control layout of the aircraft.
  • Theoretically, the lack of ailerons allows the smoother wings to have a higher aerodynamic performance due to zero control surface interference, and also allows the wings to be removed or folded easily - though the payload pylons with their control circuits do complicate this.
  • Larger drones like the Reaper with longer wings have a higher Moment Of Inertia (MOI) in the roll axis, in fact more than the bottom mounted ruddervators could overcome by themselves, so these designs do have ailerons (either wing-warping or hinged), which allows the V-tail to be upright for better control and also ground clearance on landing.
  • A crosswind on an inverted V-tail will cause the plane to yaw and pitch up rolling into the wind instead of pitching down and rolling away from it as it would with an upright V-tail. Given the high communications latency between the command in USA and the theatre in Afghanistan the control link is often temporarily lost, so this behaviour is an advantage as the aircraft usually has plenty of room above it to fly while the pilot reacts to the disturbance and hopefully restores control. Obviously the Predator can only fly downward for so long before it runs out of air.
  • The inverted tail does have the benefit of masking some of the plane's engine noise in flight from some forward angles. Not much, but every bit helps when you want to observe but not be observed.
  • Lastly, the inverted tail protects the more expensive propeller in the event of pilot error on manual takeoffs or landings.
Sorry to drone on...
Here is some info on an oft-mentioned but little understood subject:
Those pesky Reynolds Numbers – you have heard of them many times, but what are they exactly?
OK here is the science bit, with a few helpers (In Brackets) as it applies to our hobby thrown in to help it move along:
What is a Reynolds Number?
For our purposes
, the Reynolds number represents the ratio of inertial (Movement) forces to viscous (Stickiness/thickness) forces and is a convenient parameter for predicting and analyzing the performance of a body in moving air. A Reynolds number is defined as a characteristic length (Wing Chord) multiplied by a characteristic velocity (Speed) and divided by the kinematic viscosity (Thickness of air).
Mathematically, Aerodynamicists define the chord Reynolds number (Re) like this:
R = Vc/ν
Where V is the flight speed, c is the chord length, and ν is the kinematic viscosity of the fluid in which the body (aerofoil) operates, which is 1.460×10−5 m2/s for the atmosphere at sea level. Generally, the two variables V, and c can be manipulated to cover most aerodynamics problems.
The history of the Reynolds Number:
George Stokes introduced the concept in 1851, but Arnold Sommerfeld named the Reynolds number in 1908 after Osborne Reynolds (1842–1912), who performed exhaustive experiments in fluid dynamics in the 1880s.
Osborn Reynolds discovered that the fluid (In our case Air is a fluid) flow regime depends mainly on the ratio of the inertia forces to viscous forces in the fluid to determine whether the flow is laminar or turbulent.
Info: Where do our model aircraft fall in the Reynolds number range?
Typically, the Reynolds numbers, even on our small-scale aircraft tend to be very large as this enables finer and hence more accurate definitions.
So, you see that our typical fast 3M model sailplane falls somewhere around the front end of a large bird and the back end of a Cessna light aircraft.
What are Reynolds numbers used for?
Generally, Reynolds numbers are used throughout industry for engineering applications wherever fluid dynamics problems and designs need to be modelled or solved. But for this description for the sake of simplicity, we’ll confine the range of usage to our own application: Aerodynamics as applied to model aircraft.
Why do we need Reynolds numbers?
The purpose of the Reynolds number (Re) as applied to aerodynamics problems and design is to provide a base reference in order to get some sense of the relationship in air flow between the inertial forces that we want to look at.
How can Reynolds numbers be useful to us?
  • In the design of a new model airframe, the designer uses Reynolds numbers to calculate the effects and possible efficiency of different aerofoils at different wing chords and aspect ratios, thus enabling the selection of the best planform for the job(s) he wants the model aircraft to do. These calculations form a large part of a good basic 3-dimensional envelope within which - if the designer has done a thorough job - he can be sure that the model will meet its expected performance targets.
  • In a wind tunnel the use of Re enables the analysis of scale-models when laminarity or turbulence are implied.
  • In computer simulation of aerofoil performance, if we know the wing chord and we know the air velocity range that the wing will be working at, then we can derive the Reynolds numbers for a particular aerofoil. Once the Reynolds numbers are defined, then algorithms in the simulation programme are applied involving camber, thickness, and curvature of an aerofoil in order to calculate the desired parameters in a given dynamic situation. The results can often give a good indication of the characteristics and possible perfomance of a gven aerofoil.
  • In comparison situations, since the Reynolds number values increase or decrease with variations in wing Chord length and/or velocity, while the air thickness value remains the same; by varying the dynamic conditions, we can then use those numbers as a base to compare results with other aerofoils and also to predict by computer, coefficients of lift, drag, and angular performance. While not always 100% accurate, these computer simulated predictions do give a good indication of the possible performance of a particular aerofoil or flying surface.
Lastly, Reynolds numbers are closely associated with the boundary layer concept, and we’ll get to that in the next post. In practice, the study of flows developing along a solid boundary is of primary, and critical importance for the making drag reductions and flow separation performance analysis of aeroplane aerofoils and wings – even at our ‘toy’ scales.
For you home designers, – here is a place to quickly calculate your Reynolds numbers: http://airfoiltools.com/calculator/reynoldsnumber
For our purposes
R = Vc/ν
Doc,
Thank you for taking the time to populate this thread. While I am unlikely to try and design my own aircraft, I have a keen interest in learning all I can about how my models (and birds, insects, and commercial aircraft perform). I feel fortunate to have a source to turn to such as this community of fliers and builders for sharing knowledge.
I also enjoy the beauty of objects and creatures in flight and an early memory in my youth is of lying on my back in a meadow and watching a Piper Cub fly overhead and hoping that one day I, too, could slip the surly bonds of earth.
Thanks to Jure for the idea for this thread and thanks to you for getting it started.
Best,
Raymond Gaskins
Glad to see you chaps are enjoying this, but it would also be nice if others could maybe contribute too.:p
But meanwhile...
Boundary layers.
This topic is a bit more complex than those we have dealt with thus far. Boundary layer physics is used in engineering design and problem solving where any liquid is flowing alongside a fixed boundary – hence the term “Boundary layer”
Who first realized the possible presence of Boundary Layers in aerodynamics?
The aerodynamic boundary layer was first hypothesized by Ludwig Prandtl in a paper presented on August 12, 1904 at the third International Congress of Mathematicians in Heidelberg Germany. So, you can blame him for all our problems!
Please note that Boundary layer physics applies to any type of fluid, including gas, but for this little explanation I’ll just use air as the medium.
Explanation of what a Boundary Layer actually is (Parts from NASA):
Aerodynamic forces depend in a complex way on the viscosity of the air. As the air moves past an object, the molecules right next to the surface stick to the surface boundary and don’t move, or move extremely slowly, so the molecules flowing just above the surface are slowed down in their collisions with those surface adhered molecules. Those molecules in turn slow down the flow just above them.
Logically, the farther one moves away from the surface boundary, the fewer the collisions there will be and the air molecules will flow more freely. This creates a thin layer of air near the surface in which the velocity changes from zero at the surface to the free stream value away from the surface. Engineers call this layer the boundary layer because it occurs on the boundary of the objects surface to air.
Boiling it down:
The streamwise velocity varies from free stream to the surface but in reality, the effects are three dimensional. From the conservation of mass in three dimensions, a change in velocity in the streamwise direction causes a change in velocity in the other directions as well. There is a small component of velocity perpendicular to the surface which displaces or moves the flow above it, so we can define the thickness of the boundary layer to be the amount of this displacement.
The displacement thickness depends on the Reynolds number – not that bloke again! - which is the ratio of inertial (resistant to change or motion) forces to viscous (heavy and gluey) forces and is given by the equation: Reynolds number (Re) equals velocity (V) times density (r) times a characteristic length (l) divided by the viscosity coefficient (mu)
Re = V * r * l / mu​
Gasp…shudder…but that’s a relief - if we can boil this stuff down to Reynolds Numbers then it actually gets a lot simpler.
For us Modelers:
Boundary Layers can be a very complex subject, so as this is a description of the Boundary Layer effects on model aircraft only, and so we’ll restrict our coverage to aerodynamics.
On a model aircraft, the pressure distribution throughout the boundary layer in the direction normal to the boundary surface - such as an aerofoil - remains relatively constant throughout the boundary layer, and will be the same as on the surface itself.
The thickness of the velocity boundary layer is normally defined as the distance from the boundary body to the point at which the viscous flow velocity reaches 99% of the freestream velocity.
Why is the Boundary layer so important to aerodynamicists, aircraft designers, and aerospace engineers?
In high-performance designs, such as gliders much attention needs to be paid to controlling the behavior of the boundary layer in order to minimize drag. Two effects have to be considered.
First, the boundary layer adds to the effective thickness and surface area of the aircraft, through the displacement thickness - hence increasing the pressure drag.
Secondly, the shear forces at the surface of the wing and all the other surfaces of the aircraft create skin friction drag.
In other applications Boundary Layer theory can be used for something as simple as determining how much water will travel through a pipe at a given pressure, to how much the drag on the surface of a rocket will change as it accelerates out of the atmosphere.
How about on our toy planes?
At lower Reynolds numbers such as those seen with our model aircraft, it is relatively easy to design the model “slick and slippery” in order to maintain a fairly high degree of laminar flow. Indeed, for the model sailplane designer, this is probably the most powerful weapon we have in our toolbox for reducing drag.
A slick, slippery design gives low skin friction, which is obviously desirable.
You win some, you lose some:
However, as usual with aerodynamics, it’s a trade-off. The same speed range that gives the laminar boundary layer its low skin friction also makes it badly affected by adverse pressure gradients. This is important for aircraft design as increasing the air pressure has the same effect as increasing the potential energy of the air, leading to a reduced kinetic energy potential and therefore a deceleration – i.e. drag. Since the air in the inner part of the boundary layer is slower, it is far more affected by this increasing pressure gradient.
Boundary layer separation and detachment:
On a model wing in flight, as the air pressure begins to recover and normalize when passing over the rear part of the wing chord, the laminar boundary layer will tend to separate from the surface. This flow separation and detachment causes a large increase in the pressure drag as it greatly increases the effective size of the wing section. This effect can be minimized by careful design and testing of the flying surface aerofoils, but it is not intuitive, and needs a lot of trial and error in order to get the best combination of wing shape and aerofoil in order to do the work that the model will be intended for.
Caveat Emptor...
Now you might think that, from listening to or reading the discussions of the model aerofoil experts (I call them the Aerofoil Police) that the aerofoil is by far the biggest single factor affecting just about everything on a model sailplane. And you might also think from the heated discussions on the subject that the 'all new super low drag section by guru Heinrich Gefingerpoken' has smooth laminar flow over both surfaces...But in both cases you would be wrong.
Often, the lower high pressure area of the aerofoil section will display laminar, or close to laminar flow, so keeping this part of the wing clean on the model design is important.
But conversely, the low pressure, upper part of the aerofoil, at normal model speeds and Reynolds number ranges will not be laminar, in fact far from it. To achieve boundary layer attachment past 50 to 60% of the chord is actually pretty unusual - as illustrated by the diagram below which is really not far from the real model wing flow separation regime.
The “quick fix”
Because of this pesky flow separation/boundary layer detachmant problem, as you may have seen in older sailplanes and especially free flight designs, it can be advantageous to deliberately trip the boundary layer into turbulence at a point prior to the location of laminar separation, by using a turbulator. This is usually a thin ridge like a piece of thread fixed along the wing. Using this method – if done correctly, the fuller velocity profile of the turbulent boundary layer allows it to sustain the adverse pressure gradient without separating, or at least promotes later separation thus reducing the pressure drag potential.
Thus, although the skin friction is increased, overall drag is decreased. This is the principle behind the dimpling on golf balls, as well as aircraft vortex generators.
And talking of Vortex generators…
Like our models, the biggest form of drag affecting Formula 1 racing cars, that move at speeds similar to fast model sailplanes (Note I am not including DS) is boundary layer induced drag. If you get a chance to look at a formula 1 car you will see that it is literally festooned with vortex generators and flow separators until it looks like the Christmas tree from hell. These guys will go to any length to cut one tenth of a second per lap from the drag penalty.
All for now.
But meanwhile...
Boundary layers.
Logically, the farther one moves away from the surface boundary, the fewer the collisions affected by the objects surface boundary. This creates a thin layer of air near the surface in which the velocity changes from zero at the surface to the free stream value away from the surface. Engineers call this layer the boundary layer because it occurs on the boundary of the objects surface to air.
Boiling it down:
For us Modelers:
Caveat Emptor...
The “quick fix”
All for now.
Please do not take my lack of contribution thus far to be indicative of my unwillingness to share…I simply do not have enough theoretical or practical expertise in this area to be of much help.
Raymond
Hi Raymond,
Of course - received and well understood.
Actually not everyone has this kind of knowledge and experience - particuarly when it applies to smaller sized aircraft - which is half the reason for me attempting to impart what I know and have discovered. Added to that, there really is not that much very reliable published information on low speed/small scale aerodynamics to go on.
Maybe we could also do a Q and A? - If anyone has some particular aspect of low-speed aerodynamics that they would like eleborated on?
I'm open to suggestions and really would welcome some. More brains = more horsepower.
Raymond
Hi Raymond,
I will pose a series of related questions? How does aspect ratio and the taper of root to wingtip and sweep of wing from leading edge to trailing edge relate to wing performance at the typical speeds we fly our models? How does tip design for models affect flight performance compared to full-size aircraft (I.e. hoerner tips)?
At some point I would like to see these same variables discussed for tailplane design and how that integrates with overall flight performance?
Perhaps some discussion about the merits and disadvantages of canard designs.
Perhaps a look at the Rutan designs and if there are any models of these designs that have been commercially produced.
I could go on, but this is a start.
Raymond
Hi Raymond,
some good questions.
OK for your first question above:
I will deal with this as 'one-size fits all' because in wing aerodynamics on our size of model aircraft up to full-sized sailplanes the wing with the longest trailing edge will be fastest and therefor the most efficient.
As you will have noticed, for the longest time sailplane wings were high, to very high, aspect ratio with straight leading and trailing edges, or maybe straight tapered sections stuck toether to make a 'kinda' ellipse, but still made up of straight sections. These were the most efficient in both theory and in practise.
Of course the designers of the time would have liked to make the wings elliptically shaped in order to utilize the ideal lift distrbution that elliptical wings can allow, but they just couldn't do it due to construction and mould making restrictions. With CAD design, CNC machining and the range of construction materials available to us now, this is not problem and so we see more and more reverse ellipse wings.
Why reverse ellipse? I hear you ask.
If you have a high aspect ratio elliptical wing with the curve at the front shallower than the curve at the back - maybe like a Spitfire wing - then you run a risk of having the mean aerodynamic Chord (MAC) too close to the Centre of gravity (CG) which can lead to stalling behaviour. To prevent this, and still take advantage of the elliptical lift distrbution, designers now tend to make the front curve greater than the trailing edge curve.
In any case on a high performance sailplane you need lift, but in order to have it, you also have drag - sometimes many kinds of drag. In this case a good designer will try to place the lift along the wing where he will get the most benefit from it, while minimising the drag penalties. For example there is no need, and it would be a disadvantage to have a big lifty/draggy section at the wing tips.
For best perfromance the lift has to be placed where it will do the most good, with the least penalties.
Real Hoerner wing tips are unlikely to be used on model sailplanes as they wont work well at high aspect ratios - like most of Hoerner's work the applications and test models were intended for low aspect ratio, powered aircraft and not sailplanes.
Wingtips on model aircraft are a bit of movable feast.
On the larger models - I mean VERY large 6 metres and more, then there might be an advantage in upswept winglets, but frankly not much.
Loads of different wingtip shapes and configurations have been tried - especially in wind tunnels by me (!)
Of all of these I will say with some confidence that the Aft-Swept wingtip shape, possibly angled a bit to accommodate some spanwise flow will be the winner.
Correctly designed wings and wingtips are not hard to spot on the slope because they are quiet even when moving at high speeds.
Basically on model sailplanes, the planform of the tailplane is best designed following a similar shape as the wing - for the same reasons. One thing that does make a difference, especially in model Aircraft and that is to use an Elevator rather than an All Moving Tailplane. Model aircraft respond better to camber changing elevators rather than barn-door AMT arrangements. Elevators are abit more work, but they give less drag and more effect.
Raymond
I'll have a think about Burt and his Caanrds etc.
Hope the other stuff helps.
Doc
Hi Raymond,
Doc
Thanks Doc,
Definitely food for thought.
Raymond
Thanks Doc,
Raymond
Doc,
One other question along these lines. While my primary love is flying anything that I can fly and learning as much about how to understand the flight performance envelope, I also enjoy flying precision aerobatics with models, especially large models. I am getting ready to spend two weeks of training at my home field with Dave Scott who runs 1st US Flight School. He is a dear friend and full scale aerobatic champion as well and writes extensively in the US model magazines about this subject. Over the years, aerobatic kits and ARFs have migrated to having very large control surfaces with large deflections to pander to the desire of many to perform wild 3D maneuvers. While I do not begrudge my colleagues for “manufacturing what sells”, I am left with really dialing back control throws and using only enough expo to give me fairly linear control throws. And now my question, are large control surfaces with less angular movement able to lessen induced drag as compared with smaller surfaces deflected with greater angular movement on the same aircraft (except for the size of the control surfaces)? Common sense and my recent experiences have indicated that the larger surfaces with less deflection have worked surprisingly well, but I would hate to discover my errors in deduction at a critical moment and harm person or property as I push the performance envelopes of my planes.
PS: I know you have many irons in the fire, so I do not wish to unduly raise your ire!
Best,
Raymond
Doc, may you comment on this stability issue ?
I had a classic "Brooklyn Dodger" FF model converted to electric RC.
It showed a very annoying Dutch Roll ( I think it was , it is my own diagnostic ) .
The solution was to add rudder area , making it taller and wider , and also making it a compensated rudder at the same time.
This fix solved the issue, but it was no longer an original "Brooklyn Dodger" , but flew much better.
Jure,
I will chime in with my “two cents worth” on this issue…I am sure you are very familiar with the Hobie Hawk which also exhibited such tendencies. Many solutions were offered, but almost any solution that increased the area of the vertical stabilizer and rudder seemed to help, but I don’t have the math to explain this. Interested in what others think.
Raymond
If I get this correctly:
The mere fact of air flowing over the wings will create a seemingly thicker wing thus increasing drag? I presume the faster it flies the greater the drag?
But meanwhile...
Boundary layers.
Boiling it down:
For us Modelers:
Caveat Emptor...
The “quick fix”
All for now.
The overall crossection of an F1 car is an inverted airfoil such that as air goes over the car the aero forces push the car closer to the ground thus increasing the grip at higher speeds. Except, earlier this season cars were designed with so much effect until at some point the height would be lowered too much (not sure why) and the force would disappear and the car height would rise again. But then the aero forces would kick in again and lower the car until it would disappear and car height would rise again - over and over and these oscillations were pretty violent. As the season progressed some teams managed to eliminate it and some managed to mitigate it better than others.
