Taranis X9D-plus SE ACCST - wont bind to V8RF-II RXs (story as old as FrSKY)
That should make no difference. The Plus SE is still the same basic radio with a few additional options.
Your radio appears to be the X9D+ that someone added a removable antenna. (you have the standard gimbals, the SE has hall gimbals)
You can't update the internal module from the bootloader screen as this is only to update the OpenTX firmware.
You have to start the radio, long press the MENU button, page to the next page, select the "FIRMWARE" folder, use the minus or plus buttons to get to the "XJT_ACCST_2.1.0_FCC.frk" V2 file or the "XJT-Ver170317.frk" V1 file, then long press ENT key and select "Flash internal module".
Rich
Tried to flash the internal module with XJT_ACCST_2.1.0_FCC.frk just to make sure I was using that version. Loaded FW onto SD card, navigated to folder on TX, selected .frk file and selected "Flash internal module". Got "Device reset . . . " and then got "Firmware update error Device not responding [EXIT]"
Tried to flash the internal module with XJT_Ver170317.frk. Loaded FW onto SD card, navigated to folder on TX, selected .frk file and selected "Flash internal module". Got "Device reset . . . " and then got "Firmware update error Device not responding [EXIT]"
Your firmware version screen on the Radio shows what version? ( make sure its x9d+ )
This is what I have for screens on my X9D+ and just updated it successfully.
If it won't work for you it must be a hardware issue?
Rich
Hey everyone,
I'm currently using a Taranis X9D Plus with OpenTX 2.3.15 and trying to bind a FrSky Archer Plus GR8 receiver to it. Since my radio only supports ACCST D16, I need to switch the GR8 from ACCESS to ACCST mode.
I know that the Archer_Update.lua script is used to change the protocol, but I can't find a download link anywhere on FrSky's website or GitHub.
❓ Does anyone have a working copy of the Archer_Update.lua script compatible with OpenTX?
Or could you point me in the right direction where I can download it?
Thanks in advance for your help – much appreciated!
Not sure where you got the information about needing a LUA script.
My understanding is the Archer Plus receivers will bind to ACCST (V2) just by powering on with the button pressed (like registering using ACCESS), then put the Tx into bind mode.
This certainly works with my Archer R10+.
Mike
