I have bound a XJT lite external module in my Tanden XE to a X8R receiver. I am also running a TD R 18 in tandem mode. Both receivers indicate that they are bound. The R 18 functions properly. I bound the XJT in D16 mode, I had tried top bind the X8R in D 8 mode, but it would not bind. chan 1-8 without telemetry. Power is supplied to the X8R via Ch 8 via an BEVR. It is a separate BEVR than the R 18 operates on. All electric use the same battery source, 2 x 12v 12a/hr SLA's. On my XE, I have programed ch 17 driven by switch B. The transmitter indicates correct output, both in the Mix menu, as well as the Output menu.
Currentl;y all chaneels function correctly fron the R18, however there is no output from the X8R. I have tried several diffent servos and difference cables. No Joy.
My transmitter is running ver 1.5.8 FCC
I would appreciate any ideas or suggestions.
Thank yuou
Jonathan
Thank yuou
Jonathan
