I started blocking out the foam and figuring out what sizes i need. I ended up making the front 26" block out of the heavy surfboard foam. I will hit home depot this weekend and grab some lighter Rigid insulation for the back 46". I have been pretty happy with the monokote stuff at aloft and its definitely lighter covering than the other things i could do so that should help with tail weight as well. I do want the surfboard to be able to sit on the elevons upright, like a surfboard would normally sit against a railing/wall, so i am going to reinforce the elevons, probably with some light ply on the top surface so it has some more strength.
For the vertical stabilizer/surf fin i am going to have it friction fit into the fuselage. Sandwiched in some light plywood or EPP, something that is applying pressure, but will allow it to rip out in a crash.
For graphics i decided to just go with an easy classic surf design. Something like this.
View attachment 13815View attachment 13816
