SRx receiver and Switch middle detect.
gnichola
I have been playing with my new X20S trying to learn about it, setup some models, etc. and in trying to setup an SR6 I was having trouble getting the receiver into self test mode. I also have an X9D 2019 and using that radio I could get the receiver into self test, but I simply could not get it to happen with the new radio. I had noticed a setting when I first went through the radio settings that said, "Switch middle detect delay" and it was set to 100ms. I finally tried setting the delay time to 0 and then I was easily able to get the receiver into self test.
What I find odd here is that originally I had considered this switch delay and so when moving my channel 12 switch I did it slowly, with my pause at the center definitely being over 100ms, but the total time being under the time necessary to activate the self test. I think there might be a bug in the delay functionality, but I am not 100% sure. For my use, I just set the middle detect delay to 0 and moved on.
the bug continues as a problem for x20s with the pre-installed software? if so, thanks for sharing the solution of delay detect on Tx adjustability, may some other reasons also involved open access deleted
This is a handy little feature so you don’t have to listen to The call out for the middle switch when you are traveling to the furthest or nearest switch. Example my flaps are up and I throw them all the way down I only want to hear flaps down not flaps half. Kiwi4
Yes I just discovered this....no delay except 0 permits the self check
