I am attempting to set up independent ailerons on a model that previously had them wired to one connector, I need the ability to adjust aileron differential to correct for adverse yaw. I added a new connector to ail 2 and plugged that into Ch5 and attempted to make adjustments in the model setup page to add the two aileron configuration and only got one aileron to respond to stick inputs. After some fiddling around in SxR configuration I got both ailerons to operate via stick input but only one responds to the gyro in either auto level or auto correct modes.
I created a new model and got the same issue, so I did a factory reset and calibration on the Rx and attempted to set up another new model and still can not get one aileron to respond to any gyro input/corrections, Ail 2 is the one that is ignoring the gyro, even checked with a known good spare servo in Ch5 slot and no response.
I checked my X20S and ETHOS Suite says my version was out of date so I upgraded, I verified that I am running the latest stabilizer config, even re-flashed the Rx firmware. I have looked for a current tutorial on YouTube but everyone has moved on to the newer Rxs and the setup uses the Stabilizer config vice the SxR menu. I even attempted Stabilizer config and it reports reports Unable to read for device and version.
What am I missing ?
What am I missing ?
