SR8 Plus Problem NEED HELP
I am having a problem setting up the Archer SR8 plus Receiver.
The problem: can not calibrate stabilizer.
FrSky x10s: Firmware : OpenTX: vers. 2.3.15-otx (1004ef7e) Date: 2022-04-22
SR8 Plus: from FrSky download page:
Firmware: 2023-06-28, v1.0.5 1. ,The first release. 240KB
LUA SCRIPT (OPTX): AP Stab Rx_OPTX.lua , AP stab Rx Cali_ optx.lug
I set the trans. To ISRM ACCESS CH1-CH16 (14ms) set Register and the Bind said SR8 Plus.
All the servos work with the sticks, 3 way switches are set up.
The first thing I found was I could not do over the air set up for the Receiver.
The FrSky x10s with OpenTX would not show the OTA choice only s port to up date the Receiver Firmware.
Second: I down loaded the SR8 Pro. Lug files from FrSky and put the files in the root folder of SCRIPTS.
When I click on the AP stab Rx Cali_ optx.lug,
The program comes up but no pictures and after pressing ENTER the receiver flashes but the program stay on 1-1.
Same issue for me. Any news
I have had the same problem with Opentx 2.3.15, it is because the Archer Plus receivers are not included in the list of OpenTX receivers, the same thing happens to edgetx.
They say that opentx will release version 2.3.16 and edgetx version 2.9.2 that includes these receivers and solves the problem.
I have solved it in the following way:
- Calibration, I have installed the lua programs for the calibration and configuration of my Archer Plus SR8 in the tools directory and it has not worked, I have installed them in the FW directory (Firmaware) and running from here they work.
- Firmware update, I have connected the Sport port of my receiver to my Horus X10S with the cable that comes from the factory updating the firmware.
I develop and maintain erskyTx and don't use openTx, however, on discovering the problem with newer receivers not being recognised and so being unable to change the receiver options, I did some changes to openTx and I have built a small number of binary files, posted here: https://openrcforums.com/forum/viewtopic.php?t=14126.
I've checked the x9Lite version.
Mike
