SR8 aileron servo goes to full throw when switched to self level mode
oldtoolguy
I have set up my Archer (ACCESS) SR8 Pro for stabilization. It is on a 3 position switch. Stabilization works as it should in the middle switch position and turns off stabilization in the down position. When the switch is moved to the up position the aileron servo goes to full throw - the elevator still works as it should. I would assume that since the gyro works properly in stabilized mode that there is nothing wrong with the receiver.
Does anybody have any suggestions on how to fix this?
Thanks
Greg
It sounds like you need to run Self Check, except that I would expect the elevator to move as well. Did you mount the receiver upside down? If you roll the airplane does the servo eventually center itself?
