SR10+ Redundancy Setup when using stabilization?
DaveWave
I have a SR10+ that I want to setup with a redundant RX setup.
The SR10+ can only use PIN 1 as SBUSIN.
In my airplane I want to use the stabilization features as well, and the setup requires CH1 for AIL L.
As the stabilization is already setup and working with PIN 1/CH1 PIN2/CH2 etc...Do I have to unplug my AIL L (CH1), remap PIN 1 as SBUSIN, then move AIL one to a free PIN, then map that as CH1?
Will this break the stabilization function?
Thanks!
Can't you remap CH 1 to another pin? It is an option in the RX config. I know the higher receivers have this option.
According to the manual:
The SR10+ receivers have 10 configurable channel ports, each channel port can be assigned as PWM, SBUS, FBUS, or S.Port.
The SR10+ can be used as a Primary receiver in a redundant solution by setting a port as SBUS In and connecting to any other FrSky receiver equipped with an SBUS Out port.
So I would start with the receiver options menu in the RF section of your model memory. That should get you going.
