Sr10 Pro and channels 9 & 10
stephen66
The SRx series has reserved channels9 9-10-11-12 to manage stabilization features. so what do I do when needing the physical channels 9 & 10 on the RX? Can they be re-assigned new CH #s on OTX?
You can set what channel is being output to the physical pins on the Tx. So on my X20 (Ethos) go to Model>RF System and choose 'SET' >'Options' to change.
Since you are running ACCESS you have 24 channels you can use. You can remap the receiver outputs to use some of the upper channels to output on the receiver. This will be under the RF section of your model memory, (OpenTX, Fros and Ethos all should have this available) it can be a bit hidden away, but it will be in the receiver options after the receiver is bound. So in this example, you might use channel 13 to output on the channel 9 output, and 14 on output 10.
This is the same as stated above, just tried to explain it a bit more. :)
On page 1 of setup click on the receiver you have bound to. Click options under options you see a list of pins 1 through 10. You ca rea a ign 9 and 10 to 13 and 14
